RV.Net Open Roads Forum: Tech Issues: Odd thing happening.
 > Odd thing happening.
2chiefsRus
USA Somewhere
Posted: 01/09/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
This Light
I have a motion detector light that operates on 3 AA batteries that I put in the cabinet over the drivers seat. Every time I run the microwave, the light comes on. The cabinet door is closed but I can see a sliver of light on the ceiling above the cabinet. Makes me wonder what that microwave is putting out into the air. Not really looking for an answer just thought it was odd.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
BFL13
Victoria, BC
Posted: 01/09/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Zap! You're sterile! [emoticon]
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 01/09/20 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Breathe deeply. You’ll live forever. Glow in the dark. Be the marvel of your community.
DFord
Near St Louis, MO
Posted: 01/09/20 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Take your pick of these Microwave Leakage Detectors:
https://www.amazon.com/s?k=microwave+detector&i=tools&ref=nb_sb_noss_2
See if your microwave is leaking any hazardous levels.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
naturist
Lynchburg, VA
Posted: 01/09/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Probably enough RF leakage to mess with its circuitry.
bob213
Fresno, CA
Posted: 01/09/20 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Would not surprise me. We have an Amazon smart plug that loses it's wifi connection when the microwave is on and my laptop looses it's internet connection as well. They all operate on the same (or close to) frequency so the microwave must leak enough to disrupt the signal. Maybe your light is interpreting the wave as movement.
pnichols
The Other California
Posted: 01/09/20 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
It may be possible to stop your interference:
If your WiFi router and laptop can operate on the 5 GHz WiFi band instead of the common (and often default band when you get them) 2.4 GHz WiFi band ... then switch your router and laptop over to the 5 GHz WiFi band.
The 2.4 GHz WiFi band is used by a lot of inhome WiFi "gadgets", so get off this band as much as you can for any and all WiFi equipment in your home - if your equipment and router are new enough to have 5 GHz capability.
Phil, 2005 E450 Itasca Spirit 24V
midnightsadie
ohio
Posted: 01/10/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
could it be its just feeling the vibration of the microwave?
gbopp
The Keystone State
Posted: 01/10/20 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Wear a baseball cap lined with aluminum foil, you'll be fine. [emoticon]
jkwilson
Indiana
Posted: 01/10/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
PIR detectors will trigger in the presence of RF, and all microwaves leak a little. We used to have to lock-out the power in the break room at work to perform tests at the other end of the building.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
