RV.Net Open Roads Forum: Tech Issues: Odd thing happening.
 > Odd thing happening.
Thunder Mountain
Lost in the Four Corners
Posted: 01/10/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Could it be sensing the turntable going around? Try turning it off and see what happens.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
K_and_I
North Central Ohio
Posted: 01/10/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
If I remember correctly, those "motion" detectors sense a change in temperature. Could the microwave be venting some heat into that cabinet?
K_and_I
2011 Rockwood 2604
Nights Camped in 2019: 85
Do we have time for shortcuts?
Ed_Gee
Central Oregon coast
Posted: 01/10/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
What JKWilson said.....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
GenoB
Parker Strip, AZ
Posted: 01/10/20 10:59am Link  |  Quote  |  Print  |  Notify Moderator
I worked in the electronic security business for over 40 years. There are several types of motion detectors
a) PIR - Passive Infrared going into alarm when a heat source makes a sudden change in front of it. Microwave energy can set it off by saturation to the circuit board if close enough. Also vibration on the surface it is mounted on can set it off as well
b) Microwave - Goes into alarm when a solid object moves in front of it disturbing the received microwave energy. Another microwave source close by could set it off
c) Ultrasonic - Sound waves bounce off of objects and it looks for a shift in the received sound waves when a person walks in front. This is not used much anymore because all kinds of factors would set them off. Not sure if microwaves would interfere with these
* If your leaking that much microwave to set off a motion detector inside a nearby cabinet you need to look into this right away ... Try putting a piece of tin foil on the inside of the door and see if the microwave still sets if off, bet it doesn't .. that would indicate the microwave is leaking all over the place
*** Referaing to the piece of tin foil on the door, I MEANT THE WOODEN DOOR WHERE THE MOTON SENSOR IS, NOT THE MICROWAVE DOOR
* This post was edited 01/12/20 11:12am by GenoB *
