RV.Net Open Roads Forum: Fifth-Wheels: Duo Therm 65900-001 sparking but not lighting?
 > Duo Therm 65900-001 sparking but not lighting?
thetundrawolf
Arizona
Posted: 01/09/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I have an older trailer with a Duo Therm 65900-001 furnace, it's getting propane fine, and 120v, when I connect the thermostat wires the fan comes on, and it sparks, I hear the solenoids in the propane valve click on, and I see it sparking in the glass window, but it never ignites. Any ideas on why it's not igniting?
laknox
Arizona
Posted: 01/09/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Might be a bad sail switch.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Roger10378
Goodrich, MI.
Posted: 01/10/20 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Probably a spider web in the burner tube. You wouldn't hear the gas valve if the sail switch was not working.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
StirCrazy
Kamloops, BC, Canada
Posted: 01/10/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
i had the same issue with my camperi just bought. a good air gun and 10 min of blowing out the combustion side, it now works perfectly.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Chris Bryant
Arden, North Carolina
Posted: 01/10/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
That’s an old furnace, most likely needs cleaning. If it is sparking the sail and limit switches are good.
-- Chris Bryant
