RV.Net Open Roads Forum: Class C Motorhomes: Fixed: Reverse lights not working
 > Fixed: Reverse lights not working
clotus
ca
Posted: 01/09/20 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hey all,
My reverse lights have not been working on my 2017 Winnebago Minnie Winnie 31K (2016 E-450 chassis)for about a year now. I finally have some time to trouble shoot it tomorrow, by myself.
I have already checked the bulbs and they are good. I will be checking the fuses tomorrow. Now for my questions:
1) If I put the ignition to "on" can I put the gear selector into reverse and will it send power to the lights without the motor running?
2) If it is not getting power, where is a common fail location I can check before I bite the bullet and re-run the wire
My multimeter is standing by and ready to solve this rather dumb problem.
Thanks!
* This post was edited 01/10/20 06:46pm by clotus *
Current: 2017 Winnebago 31K
(Sold): 5th wheel: 2015 Heartland Sundance XLT 245
Stim
NE Florida
Posted: 01/09/20 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
They should work with ignition on, engine off, BUT set parking brake!!
In order I would check- Bulbs/sockets, fuse, back up switch and switch connection.
DrewE
Vermont
Posted: 01/09/20 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yes they work in reverse with the key in the on position but the engine not running.
Check for a bad ground connection at the lights; that is a common fault and one sometimes tricky to diagnose if you are not specifically looking for it.
pushtoy 2
texas
Posted: 01/10/20 05:00am Link  |  Quote  |  Print  |  Notify Moderator
i would look for a bad ground. first check the bulb socket
DREAMER ">
clotus
ca
Posted: 01/10/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Perfect, thanks for the fast replies. I will be working on this shortly and will post back.
bobndot
Posted: 01/10/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Ford I think has 2 fuses for rev lights, one inside the cab and another under the hood. Check yours to see if that's the case on the 2016 model.
One other thing that comes to mind the 7 way trailer plug at the rear.
The trailer plug and reverse lights might be a 'T' off a main line . Testing the plug will tell you if the problem is before or after the split to that plug.
Just trying to isolate things for you.
clotus
ca
Posted: 01/10/20 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Great idea! I will check for the second fuse and the trailer wiring. Keep me’ coming!
bobndot
Posted: 01/10/20 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
If that rear plug works you could mount a set of LED's to the rear bumper and plug them into that plug, or run a 2nd plug off of it. You will then have a much brighter set of backup lights.
clotus
ca
Posted: 01/10/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
UPDATE: So although I had initially checked the bulbs, I only looked at the filament. Well, after checking the fuses and relays I pulled the bulbs and wouldn't you know they were both corroded at the base! Replaced the bulbs and BOOM problem solved!!!!
I am very happy it was such an easy fix. I used some butyl tape to seal up the lens. I was all out of geo-cel in clear so I ordered up some more to finish up sealing the tail light assembly properly and I should be good to go.
Thank you all for your suggestions.
ScottG
Bothell Wa.
Posted: 01/10/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update and I'm glad it was simple!
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
