RV.Net Open Roads Forum: Class C Motorhomes: Fixed: Reverse lights not working
 > Fixed: Reverse lights not working
ronfisherman
SE Michigan
Posted: 01/11/20 05:05am Link  |  Quote  |  Print  |  Notify Moderator
clotus wrote:
UPDATE: So although I had initially checked the bulbs, I only looked at the filament. Well, after checking the fuses and relays I pulled the bulbs and wouldn't you know they were both corroded at the base! Replaced the bulbs and BOOM problem solved!!!!
Before you seal the light up you may want to put some protectant on bulb and connectors. One product is Camco 55013.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Super C Group Forum
clotus
ca
Posted: 01/11/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Good idea. I think I have some dielectric grease laying around.
Current: 2017 Winnebago 31K
(Sold): 5th wheel: 2015 Heartland Sundance XLT 245
Posted: 01/11/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Yes dielectric grease is your friend in this situation. If the terminals in the assembly are corodded, clean them up first. Sanding, wire brush, Coca Cola if it's electrical corrosion.
Then grease em up good.
I wouldn't try to seal the bulb to the socket or use sealant on the lens though.
Glad it was an easy fix.
DrewE
Vermont
Posted: 01/11/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
If you do seal the lens, think of leaving a hole at the bottom so that any water that does manage to get in has a route to get out again, rather than just sitting there forever and ever. Maybe even drill a weep hole...
clotus
ca
Posted: 01/11/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I checked, the bulb was corroded, the socket was good.
Good call on the sealing of the lenses. I always seal a little more than 3/4 around leaving the bottom center unsealed to let any water escape.
