RV.Net Open Roads Forum: Technology Corner: HP Officejet 4622 Printer Problem
 > HP Officejet 4622 Printer Problem
haydoracin
north central, Illinois
Posted: 01/10/20 06:37am Link  |  Quote  |  Print  |  Notify Moderator
I have the above print, scan, copy, fax printer. It has been working fine until I recently needed to replace the black ink cartridge. The existing set of 4 ink cartridges was an off brand that were working fine. Replaced the black cartridge with an HP cartridge. Since then it will not print black. Thought maybe I got a bad cartridge so I bought another HP cartridge. Still no black printing. If I change the copy to blue it prints fine. My thinking is maybe HP will not let the black cartridge work with the off brand color cartridges. Any thoughts? We live in a town with WalMart the only choice for supplies. Looked yesterday and they did not have a black cartridge of the off brand in stock or I would have tried that. With the exorbitant cost of ink cartridges I hate to keep experimenting. Might be cheaper to buy a new printer.
Hayden & Jan
1994 Southwind 33L P-Chassis 454
2006 Chevrolet HHR
OTY (Mini Dachsund)
lap527
Ocala, Florida
Posted: 01/10/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Did you take the plastic protectors off the new print cartridges? Also did you calibrate the printer?
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer Hauling 2014 Tri-glide Harley Davidson, recently added a 2016 Livin Lite 21RBS travel trailer. No Wood!No Rot!
haydoracin
Posted: 01/10/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Yes and Yes
tomman58
Southeast Michigan
Posted: 01/10/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
and you cleaned or purged the cartridges, Did you try to print in b/w?
If you did the furutre looks dim for that printer
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
haydoracin
Posted: 01/10/20 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Yes and Yes!
Printer worked fine before I changed cartridges.
DFord
Near St Louis, MO
Posted: 01/10/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I detest inkjet printers. Laser printers are the only way to go. I once bought fabulous inkjet printers for myself, my daughter, my mother and my sister. I ended up tossing them all in the dumpster when the ink clogged the tubing inside them.
Keep in mind new printers no longer come with full ink cartridges. They've only got enough ink to get you started making you buy more ink. They could give you the printer for what they're overcharging you for the ink. Try Amazon or Ebay for your supplies and let the vendors ship it to your door.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
bgum
South Louisiana
Posted: 01/10/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Never will forget when Panasonic came out with typewriter s. Light and cheap. The cartridge cost an arm and leg. Soon junked the machines. Same with ink jets. Cut your losses and buy a laser printer either color or black.
Johno02
Lexington, TN USA
Posted: 01/10/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
If you printer is connected to your WiFi, HP can and does control it. I was going to quit their Insta-Ink package, so when I called to end it, I was told that the printer would no longer work, unless I went and bought NEW HP print cartridges. I would advise walmart for a cheap replacement, Our store was running a special on a PIXMA for under $25 dollars. Cheaper to replace the printer than the ink! About laser printers, do they print color??
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
IAMICHABOD
Sunny So Cal 90713
Posted: 01/10/20 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I had pretty much the same problem on my HP Officejet of another style.
When I put the off brand color cartridges in a pop up on my computer saying that they were not compatible but it still printed black but it was spotty and doing all the cleaning and other tests it did not help.
I changed all to the off brand and it all worked but every time I changed out a cartridges I got the same popup.
I purchased all my off brand cartridges from Amazon. Still expensive but they worked. The HP just got more and more problematic and I purchased a Epson 3600, much better and the ink lasts longer and the tanks are refillable,I shopped around and found one on sale.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
opnspaces
San Diego Ca
Posted: 01/10/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have any advice on the inkjet. But I'm one of the ones who went to a laser printer and have never looked back. Yes it's only black and white. but I'm still on the same toner cartridge that it came with new at least 7 years ago. Inkjet printers are just a waste of time and money as the cartridges dry out or stop reading.
As far as color laser printers. Yes they do exist, they just cost more than a black and white.
* This post was edited 01/10/20 01:38pm by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
