RV.Net Open Roads Forum: General RVing Issues: Compartment Door Slam Latches
 > Compartment Door Slam Latches
zigzagrv
Nazareth, PA
Posted: 01/10/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Is anyone having a problem of the above slam latches breaking and not being able to open the compartment doors? I have had two of my twelve latches that have broken cams, which operate the lock bolt when you lift up on the handle. It is a difficult process to get the doors open, including drilling a hole in the bottom of the assembly and inserting a long, thin screwdriver to push the bolt up to open the door.
There is no name on the latch assembly, other than 'Made in China', to find out who makes them. I did find a picture of a similar latch on the web and it appears to be made (imported?) by AP Products. However, there doesn't seem to be individual parts available for them.
I ended up making a cam from steel (5/32" thick) for the first one that broke, which required a lot of time cutting and grinding it to shape. I have since had a second one break while on the road. This time I used aluminum stock to recreate it.
New latches are available at prices for 40 bucks and up. However, they would have to be painted to match your color.
Now, I have ten more to go. Let me know if anyone else is having a problem with these type latches and if you have found parts for them.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
MFL
Midwest
Posted: 01/10/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I had a slam latch on patio side basement door that did not want to release easily. It was a nuisance, but pulling jiggling, it would release. I noticed door manfs name on inside of door, so gave a call. They said some earlier latches had problems releasing, and sent 2 new ones no charge. New one works great and easy to change out. They sent new keys as well.
Sorry, can't remember the manufacturers name, and no access to FW now.
on edit: light bulb just lit...the manuf was challenger door
Jerry
* This post was edited 01/10/20 08:53am by MFL *
Gonzo42
California
Posted: 01/10/20 08:50am Link  |  Quote  |  Print  |  Notify Moderator
I had a broken one and found replacements on ebay, inexpensive.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
ScottG
Bothell Wa.
Posted: 01/10/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Mine have been surprisingly flawless but I'm gentle with them. I never actually "slam" the doors.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
ependydad
Here and there
Posted: 01/10/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Another who haven't had issues, but since it sounds like replacing them is a pretty big hassle.. can you buy the replacement and then just salvage the parts?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
zigzagrv
Nazareth, PA
Posted: 01/10/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
At first, I thought letting the door slam is what put stress on the cam. After taking it apart and watching it operate, slamming it shut does not involve the cam. The cam only comes into play when using the handle to open it. The cam itself is made from brittle pot metal which breaks at the pivot point.
zigzagrv
Nazareth, PA
Posted: 01/10/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I'm not willing to pay $40+ to replace a 50 cent part. For the rest of my doors, it would cost me over $400.
Cummins12V98
on the road
Posted: 01/10/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
challengerdoor.com they are in Elkhart, IN. Great people, I changed out all my non lockable to lockable with parts from them.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
janstey58
Glenwood, IA
Posted: 01/10/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
I dont slam my doors, instead upon closing I release the latch with my right hand and "knee" the door closed, then release the latch. Never had on break yet.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
ependydad
Here and there
Posted: 01/10/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I don't disagree, but it sounds cheaper than buying a whole new latch + having it painted to match.
Hope you can find the part you need.
