RV.Net Open Roads Forum: General RVing Issues: Compartment Door Slam Latches
 > Compartment Door Slam Latches
Chum lee
Albuquerque, NM
Posted: 01/10/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Regular shots of silicon spray on the handle pivots and latches helps the mechanisms stay lubricated and last longer. Slamming the doors, . . . . . NOT!
Chum lee
zigzagrv
Nazareth, PA
Posted: 01/10/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee
There's a reason they are called 'slam latches', and are made to be closed without using the handle. As I have said before, when you close the door on mine, the striker pushes the bolt UP AWAY from the cam. The cam is there only to move the bolt up with the handle.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
GDS-3950BH
DC
Posted: 01/10/20 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
zigzagrv wrote:
ependydad wrote:
Another who haven't had issues, but since it sounds like replacing them is a pretty big hassle.. can you buy the replacement and then just salvage the parts?
I'm not willing to pay $40+ to replace a 50 cent part. For the rest of my doors, it would cost me over $400.
Are you sure it's not one of the high quality, sure to break, LIPPERT overpriced slam latches? In which case $40 would be a bargain.
zigzagrv
Nazareth, PA
Posted: 01/10/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
There is no brand name anywhere on the lock....only'Made in China'
HERE is a link to the lock on Amazon.
GDS-3950BH
DC
Posted: 01/10/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Here you go, Fastec AKA Wesco.........
$13.95 which means they cost about $1.50 or less to manufacture.
cross21114
Baltimore, MD, USA
Posted: 01/10/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I had this happen to the latch on the door where the propane is after driving to Alaska over lots of road construction. Since the propane tank is open underneath, I think all the fine dirt got in the latch making it difficult to open. I finally forced it open and the stiker broke. Fortunately I had an extra latch when I replaced the unlocking fuel door with a locking latch so I was able to replace it. Because it was open underneath I was able to remove the latch from the backside of the door. Don't know how I could have done this if it were on one of the closed compartments.
I should get a spare in case I have a repeat. There are 3 compartments which are open underneath.
Chris
2018 Nexus Ghost 36DS
360 Cummins, 3000 Allison
2016 Ford Expedition
Chum lee
Albuquerque, NM
Posted: 01/10/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
zigzagrv wrote:
Chum lee
Do what works for you. Thank you and yes, I'm very familiar with how the handles/strikers/latches work. Slam latches? I guess we went to different schools. Who is this "they" you refer to? (rhetorical question)
Chum lee
zigzagrv
Nazareth, PA
Posted: 01/10/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee wrote:
zigzagrv wrote:
Chum lee
Chum lee
Rhetorical answer; the 'they' refers to the slam latches themselves. Read carefully.
zigzagrv
Nazareth, PA
Posted: 01/10/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! Thanks for that! Guess I didn't go far enough in my search.
