RV.Net Open Roads Forum: Class A Motorhomes: Electric steps
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Electric steps
myface
Posted: 01/10/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Does any one know where I can find wiring diagram for electric steps. Previous owner did some "modifications" and cut some wires off.
2001 Brave SE 29A
enblethen
Moses Lake, WA
Posted: 01/10/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I am guessing you have a Kwikee step.
Kwikee wiring diagram
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Near Annett’s Mono Village, Bridgeport, CA
Posted: 01/10/20 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Bless those former owners who cut wires off, for they know not what they do.
Wherever I happen to park
Posted: 01/10/20 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Just so you know.. On my Steps there is a wire that is cut... Still not sure what it is for. the reason it's cut is it has no use... It appears to be an "Extra wire" near as I can tell.
Home is where I park it.
enblethen
Moses Lake, WA
Posted: 01/10/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
The 16 gauge purple wire is not normally used. It is used on some for optional(extra)step lights.
myface
Posted: 01/11/20 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the wiring diagram. I will check it out.
myface
Posted: 01/11/20 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
The previous owner cut the wire from control box and run wire straight from motor to battery with alligator clips. It could be that control box give up and he bypass. I got some work to do with that.
enblethen
Moses Lake, WA
Posted: 01/11/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would not condem the controller without doing some testing. Quite often there could be ground issue or the magnetic door switch.
Control box should be available from Colaw RV salvage. Colaw
What color is the controller?
dougrainer
Carrolton, Texas
Posted: 01/11/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Since you have a 2001. The step controller is no longer available. This link points you to the ONLY and best solution for getting your step back to OEM. Doug
https://store.lci1.com/kwikee-step-motor........-and-quad-steps-kwik-step-motor-kit.html
myface
Posted: 01/12/20 05:57am Link  |  Quote  |  Print  |  Notify Moderator
OUCH. I just put a rocker switch by the door.
 > Electric steps
