RV.Net Open Roads Forum: Tech Issues: HWH front right
 > HWH front right
tarnold
georgia
Posted: 01/12/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Op again. Just spent more time looking for that roller bearing. As for mp65-3035 that is for a 9000# jack. Don’t look anything like mine. Mp65-3030 is what I seem to have 6000#, no bearing?
enblethen
Moses Lake, WA
Posted: 01/12/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
MP65-3030 is 6000 jack.
It does not show roller. It is located on upper end of the control rod.
Are you sure you have HWH? Can you get number off it?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Posted: 01/12/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Correct. No bearing. But, Look at where it states Vertical stop adjustment. Does your Jack (all 4) tilt slightly down? If not, then tighten the vertical adjustment bolts to Pull the jacks down slightly. After 20 years the cables are probably slightly stretched.What I do is spray Liquid Wrench all over the pivot points to penetrate and remove any rust/corrosion that hinders the jacks from freely moving. You should be able to grab the foot and pull down vertical easily and the jack will smartly spring back up. Doug
tarnold
georgia
Posted: 01/12/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Again thanks all. All 4 do tilt slightly downward. These are on a 2014 unit.
 > HWH front right
