RV.Net Open Roads Forum: Adding extra solar panel to 2019 Northern Lite
 > Adding extra solar panel to 2019 Northern Lite
devildog1971
Rome
Posted: 01/10/20 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
My Northern Lite came with one 95 watt solar panel. I would like to add another but my solar knowledge is lacking. does the second panel have to be a 95 watt panel or can I add a 100 Watt The one is almost like a trickle charger not enough to charge from 50% even in sun most of the day
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
pianotuna
Regina, SK, Canada
Posted: 01/10/20 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
In a perfect world the added panel should be identical. In real life, if the voltage is less than one volt different, it may work well in parallel.
Regards, Don
Camper_Jeff_&_Kelli
Seattle
Posted: 01/11/20 12:43am Link  |  Quote  |  Print  |  Notify Moderator
I have an old 67 watt thin film Unisolar panel. I added a new 170 watt GoPower mono crystal panel. Both have the same voltage rating and have worked very well together for about a year now. Or splurge and get two new panels.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
naturist
Lynchburg, VA
Posted: 01/11/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Same voltage, different amperage, put them in parallel. Same amperage, different voltage, put them in series.
Kern County, CA
Posted: 01/11/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
What wire size did the manufacturer use and what is the length of the run from the panel to the controller? Is your controller rated to handle the additional amps?
scout4trout
Cody, WY
Posted: 01/11/20 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
We added a 100 watt panel last summer to our Northern Lite and it really made a difference. Lots of info about adding panels on the Facebook NL group.
2017 Ford F250 XL STX SCSB 6.2 gas with camper package, Torklift Tiedowns & Fast Guns, Airbags, payload 3,436
2017 Northern Lite 8'11"Q Sportsman with preferred options
Old Days
Colorado
Posted: 01/12/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
I just put another 100 watt panel on my 811. I have put solar on before and I have had good luck with Renogy products. The charge controller that Northern Lite installs at the factory is a pretty good one.
