RV.Net Open Roads Forum: Tech Issues: No Reception on TV
 > No Reception on TV
ENG2242
Missouri.
Posted: 01/11/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I looked for the standard on and off switch to activate the antenna. However, I cannot find one and I’m not able to utilize my TVs through my antenna. Any suggestions?
David Hartmann
2018 Bighorn 3870FB
2007 Dodge Ram 2500 CTD 5.9
Prodigy 2
Auto-Slide Hitch
Firestone Air-Bags
Lynnmor
Red Lion
Posted: 01/11/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Did you do a channel scan?
Are you some distance from a TV tower?
Can you temporarily connect a cheap portable antenna?
Do other nearby campers have reception?
bucky
Raleigh metro
Posted: 01/11/20 08:03am Link  |  Quote  |  Print  |  Notify Moderator
If you have a bedroom tv the booster should be in that area so that it can feed multiple tvs.
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
schlep1967
Harrisburg, PA
Posted: 01/11/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Keep looking. Check in cabinets and under shelves near every television or television mount. The other option is to post your unit make and model so someone else that has the same one can direct you to it.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
DFord
Near St Louis, MO
Posted: 01/11/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
The OP has his RV listed in his signature - he needs help on his 2018 Bighorn 3870FB
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
ENG2242
Missouri.
Posted: 01/11/20 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I have torn this place apart looking for the booster switch. No luck. I know what to look for as this is my 6th RV.
MDKMDK
Canada
Posted: 01/11/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
If this is a Heartland RV, the owner's manual says
"Television Viewing
Set TV to proper reception mode – go into the menu function of the TV and select either “air” or “cable”.
Antenna – Make sure TV booster is turned on (in bedroom TV cabinet) for “air” reception.
TV booster needs to be in the off position for the park cable signal to be passed through to the TV.
Tune channel as needed.
Audio can be routed through the Audio System by turning radio to “aux” input (“FNC” button)."
I believe the OM on their website that I took this from is a "general" version for multiple unit types.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
jkwilson
Indiana
Posted: 01/11/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
The best place to install a booster is as close to the antenna as possible. For that reason, most are in the bedroom very close to the antenna.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Dave H M
IL
Posted: 01/11/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
mine is like bucky's and inside the upper right cabinet while facing the front.
MDKMDK
Canada
Posted: 01/11/20 11:19am Link  |  Quote  |  Print  |  Notify Moderator
OP appears to have either given up, or found it? Update?
