RV.Net Open Roads Forum: Tech Issues: Ultimate power inverter/charger question
 > Ultimate power inverter/charger question
SoundGuy
S Ontario
Posted: 01/11/20 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Crushedstang50 wrote:
Yes my plan was to just disconnect the stock coverter/charger.
Why bother disconnecting the converter? [emoticon] Since your intention is to power your trailer "whole house" with the inverter just turn off the converter and plug your trailer's 30 amp main service cable (using a dogbone) into the inverter output - done. [emoticon] At times when you're not using the inverter just turn the converter back on again. K.I.S.S. [emoticon]
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
2oldman
Ca
Posted: 01/11/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
It's an inverter/charger.
Crushedstang50
Wichita, KS
Posted: 01/11/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
The storage I'm hoping won't be too big of an issue..... there is a bit of angle at the top front where I will mount it. So my hopes are it will not impede storage too bad. I won't know for sure until I grab her out of storage.
I like the idea of putting plugs on to easily swap supplies if need be.
rrupert
NW PA
Posted: 01/12/20 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Does the inverter/charger have a fused 120-volt input? If not you should wire it into the power center breaker panel where the converter is now connected.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Crushedstang50
Wichita, KS
Posted: 01/12/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
It has a breaker on the ac output. But I should probably put another breaker on the shore power line going to the inverter. Better safe than sorry! Thanks!
BFL13
Victoria, BC
Posted: 01/12/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
I posted this yesterday, but people must have missed it. The pdf manual is linked in this, scroll down. Do what it says.
https://ultimatepower.com/products/inver........s/3000w-pure-sine-inverter-charger-pcul/
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
theoldwizard1
SE MI
Posted: 01/12/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
It does have an automatic transfer switch built in. You are better off REMOVING the old converter and hooking your 12VDC fuse panel directly to the battery bank.
From the manual
While in the Standby (charging) Mode, the AC input is continually monitored. Whenever AC power falls below the Trip voltage, the inverter automatically transfers back to the Invert Mode with minimum interruption to your appliances - as long as the inverter is turned on. The transfer from Standby mode to Inverter mode occurs in approximately 10 milliseconds. And it is the same time from Inverter mode to Standby mode.
pianotuna
Regina, SK, Canada
Posted: 01/12/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Not removing but rather just disconnecting the OEM 120 power feed to the converter may be a better choice.
Regards, Don
Wherever I happen to park
Posted: 01/12/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Both yes and now. First the existing converter (I gather it's part of the breaker panel) you can disable. Just turn off the breaker or lift the wire off the breaker (you may need to do a bit more work than this)
Page 2: Now the inverter should be placed NEAR (not next to but in the next compartment over) from the batteries.. With a 3KW inverter you need BIG, HEAVY cables connecting we are tralking 00 or 0000 depending on the run. And a big fuse (30000 watts is around 300 amps at 12 volts so you may need a fuse... bigger (read the owner's manual for the proper size)
But wire that big is EXPWENSIVE so make sure you keep the run short as possible.
Final bit of advice. tape the black and red 12 volt wires side by side for as much of the run as possible.
Suggest battery size. One pair of GC-2 (6 volt two in series make 12) per thousand watts.
Home is where I park it.
deltabravo
Spokane, WA
Posted: 01/15/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
with it can't I just bypass my stock converter/charger.
Yes. On my RV, it was easy to do.
Here's how I did it.
2015 Nash 17k (bought pre-owned 5/23/18)
