RV.Net Open Roads Forum: Tech Issues: Deciding on Battery Replacement
 > Deciding on Battery Replacement
Son of Norway
Denver, Colorado
Posted: 01/11/20 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all, my question is: What are the best way(s) to tell if an AGM battery has lost enough of its capacity that it should be replaced?
(And if it's anything complicated I will probably need advice on how to do it.)
Thanks for your help.
(I should add that this is a group of 54 amp-hour CD Technologies Hi-Rate Max batteries that I have been using in parallel in the RV. I took them out and right now I have them in my house charging.)
* This post was edited 01/11/20 02:25pm by Son of Norway *
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
Yosemite Sam1
Under the pines.
Posted: 01/11/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Take it to Pep Boys and they will tell you. But better to have it checked by the authorized dealer of your battery brand.
Mine went dead after 3 months. The dealer replaced it free even if I did not buy it from them. Most batteries have 3-year warranty.
BFL13
Victoria, BC
Posted: 01/11/20 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
https://batteryboss.org/shop/ups12-210mr-cd-vrla-battery/
The 20 hr rate on a 54 AH battery is 2.7 amps. So a full battery ought to be at 50% SOC after 10 hours at 2.7 amps.
So do them one at a time (in case some are good and others not so good while in your parallel bank)
Find the voltage vs SOC table for those AGMs. EG, mine are 13v full and 12.4v at 50%. YMMV so find the right numbers.
Charge each one to full, run a 3 amp load such as a typical RV two bulb lamp and check its voltage after 5 hours. (Disconnect the load and wait half an hour for the voltage to bounce back.) If the battery is as new, it should be about 75% SOC.
If it is lower than that, you know the battery is not like new. Keep going, spot checking each hour from now on. Say it gets to your 50% voltage at 7 hours.
That means your battery is only 70% good as new. 8 hours is 80% and so on.
Now it is up to you how much capacity remaining is enough.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
pianotuna
Regina, SK, Canada
Posted: 01/11/20 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Were they wired in a balanced manner? How many are there?
Are your batteries on this page?
https://www.batterysharks.com/C-D-Techno........sDaqEuLHnrVILdGNQSc-JzIJWFoaAm1EEALw_wcB
Son of Norway wrote:
Hello all, my question is: What are the best way(s) to tell if an AGM battery has lost enough of its capacity that it should be replaced? Hi
Regards, Don
time2roll
Posted: 01/11/20 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
If voltage is dropping to where you are not sure if the furnace can go all night.... time for new batteries.
675w Solar pictures back up
Son of Norway
Denver, Colorado
Posted: 01/11/20 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
They are the UPS12-210MR. Three batteries. They were pretty well balanced intially, but now they are within about 2/10ths of a volt. They date from 2010 and 2011. On our trip in November the resting voltage of the group was about 12.8 volts.
* This post was edited 01/11/20 03:47pm by Son of Norway *
2oldman
New Mexico
Posted: 01/11/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
It's time.
pianotuna
Regina, SK, Canada
Posted: 01/11/20 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
For balancing an odd number of jars only method #3 works.
http://www.smartgauge.co.uk/batt_con.html
But the existing batteries have served their time--I would replace.
covered wagon
Posted: 01/11/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
The simplest solution always seems to work the best.
Veebyes
Posted: 01/12/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Get one of these. https://www.amazon.com/OTC-3180-Battery-Load-Tester/dp/B000F5HU6C/ref=sr_1_11?crid=UXILT2AA3Z&keywords=battery+tester+automotive&qid=1578837992&sprefix=battery+test%2Caps%2C208&sr=8-11 Well worth th money.
How old are your AGMs? My last one, a 4D 215AH Lifeline, had a service life of 9 years.
2007 Alpenlite 34RLR
