RV.Net Open Roads Forum: 91f53 chassi in Yukon at -40f where is shift interlock
 > 91f53 chassi in Yukon at -40f where is shift interlock
Wilsonintexas
Wylie
Posted: 01/11/20 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I am stuck in the Yukon at -40f
In a
92 Rockwood on a 91 F53 chassis gas engine
I have a few isues
- the ignition key lever internal to the column broke
- I removed the key and column collar and the broken alum piece
- I can manually move the rod that controls the ignition on and starter
BUT I suspect at these low temps some of the solenoids are stuck
1) The shift lock is stuck and I cannot get it out of park.
- the brake lock works
- I have tried the work around of brake on, turn on ignition, move down one detent. Shift to neutral. Still no luck
2) The starter will not kick in expect that the neutral safety switch is also having problems
So the questions:
Where is the shift lock solenoid located? I have been looking but at -40 F I cannot stay out there long. I would like to remove it for now.
I found the park and neutral switch can but I do not have the plug configuration to bypass the switch.
* This post was last edited 01/11/20 04:24pm by Wilsonintexas *   View edit history
Wilsonintexas
Wylie
Posted: 01/11/20 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
I tried several online manuals with no luck
I tried just answers and it looks like there is no solenoid on this year instead a part of the ignition lock that broke in the stealing column is the lick and part of it is still there
I saw a piece that was still there but was not sure that that was the problem
Tomorrow I will pull the stealing wheel again and drill a small hole and get it out
I will let you know if that solves the shift lock problem
I will try to get pictures
