RV.Net Open Roads Forum: Towing: B&W pivot arm adjustment
Search only in Towing
Open Roads Forum  >  Towing
 > B&W pivot arm adjustment
Hedgehog
Fairhaven, Massachusetts
Posted: 01/12/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
So I purchased the B&W RVK3305 for the ford puck system on my 2019 F-450 and wanted advise on the pivot arm placement. I understand the height and bed rail clearance but I have the option of the kingpin 3” in front of the axle or 1” in front of the axle. I was wondering how much difference it would make between the two. I was thinking about doing the 1” in front of the axle to gain 2” of clearance between the front of my fifth wheel and the tailgate when it is open. Where I had my previous slider on my shortbed, having the hitch in the rear position gave me way more room between the tailgate and fifth wheel. Any input is appreciated
fj12ryder
Platte City, MO
Posted: 01/12/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
A couple inches will make minimal difference. IMO as long as the pin is forward of the rear axle it's good. A couple inches isn't going to affect the handling of the truck/trailer at all. IMO of course.
Howard and Peggy
"Don't Panic"
Cummins12V98
on the road
Posted: 01/12/20 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Place the two head support brackets that the head sets on FULL forward with the straight edges towards the cab. Adjust height to give at least 6" bed clearance.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Hedgehog
Posted: 01/12/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Cummins 12v98, so looking at the b& w instructions for your ram, your hitch is 2” in front of the axle. So that is right in between the two settings I have to choose from. I will put it together tomorrow and see my clearances with the trailer before I torque everything down. I would rather have my kingpin in the 3” forward position but like I said, I’m concerned with tailgate to camper clearance with tailgate down. You can’t always be perfectly straight with your trailer when your hitching up.
Cummins12V98
on the road
Posted: 01/12/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
More weight on the front axle the better.
Hedgehog
Posted: 01/12/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Totally agree, I’m sure either way, going from a gas powered srw 1 ton to a diesel power F-450, my towing experience is gonna be night and day. I could have kept my Reese elite slider from my last truck but I really wanted to go with the b&w
fj12ryder
Platte City, MO
Posted: 01/12/20 10:46am Link  |  Quote  |  Print  |  Notify Moderator
You can't go wrong with the B&W.
Cummins12V98
on the road
Posted: 01/12/20 11:36am Link  |  Quote  |  Print  |  Notify Moderator
U gots dat right!
MFL
Midwest
Posted: 01/12/20 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
With the long bed, full forward would likely tow best. However, I would be happy with one inch forward, if you would rather have the extra gate to camper space. The arms aren't hard to move, so I'd try it both ways at some point. I doubt you'll notice much difference.
What you will notice is that hitch!! You will soon be telling others of the reliability and ease of use.
Jerry
jaycocamprs
Ringgold Georgia
Posted: 01/14/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I run mine set to the rear. I'm not sure what the effect is on the front axle weight, but it does not feel light. With a long bed, double cab truck I doubt that it offsets the weight of the diesel engine.
With the GM puck mounts reversing the base in the mounts will set the arms either forward or rearward, the Ford looks to be the same. Try it, I doubt it will drive any different which ever way are arms set.
What you will gain is clearance with the tailgate down, and a little more angle before hitting the overhang with the bed corners.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
