RV.Net Open Roads Forum: Plug in truck bed or use plug in bumper for 5th wheel
Search only in Tow Vehicles
 > Plug in truck bed or use plug in bumper for 5th wheel
Cummins12V98
on the road
Posted: 01/12/20 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
Jim2007 wrote:
Hi All, My 2016 Dodge truck came with a plug in the bed and one on the bumper. I use the in bed one for the 5th wheel because it keep the electrical cord from coming loose. Jim2007
How did you get a 201 Dodge Diesel, they quit making them in 2008 and removed all labels that said Dodge in 2011 or so.
Last year was 2012. It said Dodge in one place on my Dads on the center of dash on the black recessed area for sunglasses. It was there for legal reasons. Starting 2013 Dodge was no longer. It was then officially RAM.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
thomas201
Eastern Panhandle WV
Posted: 01/13/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
On a 2012 Ford I found a slick way to get an in bed plug without drilling a hole. Buy a whip, plug it into the bumper outlet, remove the drivers side taillight and route it neatly up through an existing hole in the bed. Then install the plug on the end of the whip. Mount it snugly, with just enough room to open the plug cover, with an "L" bracket under the bed rail. Then test, and put the taillight back.
Works well, you don't bash up the plug, keeps everything dry and is easy to reach flat footed from the ground. Hand finds hand when you plug it in.
Dave H M
IL
Posted: 01/13/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I have an old 2012 F250. On that model the rear bumper harness used a plug to connect to the harness coming from up front. As i recall, Bargman mane an in bed harness that got its connection by acting as a sandwich between the rear two plugs. Then you cold get different lengths with 7 pin RV plug molded at a 90 degree angle for install where ever you wanted to drill in the bed. I moved mine up toward the front of the bed and it is not hard to reach on my 2 wheel drive puller.
