RV.Net Open Roads Forum: Tech Issues: Sylvania Microwave Oven - SC-11100
 > Sylvania Microwave Oven - SC-11100
pianotuna
Regina, SK, Canada
Posted: 01/12/20 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Unplug it. Wait 5 minutes. Plug it back in.
If that doesn't solve it, go to a store for a replacement unit.
Regards, Don
buddhawolf
New York
Posted: 02/22/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still doesn't work, it may be a bad door switch or door switch mount.
One quick check is to gently hold down on the door while you press Start (or Cook).
Refrigerator review
