RV.Net Open Roads Forum: Class A Motorhomes: SOLVED No 12V
myface
Posted: 01/12/20 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I do not know how, but I lost all 12V in coach. I have 12v when the gen is running but if I turn off gen the 12V is off. I can not locate master switch - if any.
* This post was edited 01/13/20 05:01pm by myface *
DFord
Near St Louis, MO
Posted: 01/12/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
To get a good answer, give a little information about your RV. There might be someone on here with the same year/brand/model that's already run into your problem and fixed it.
You may have what's called a "salesman's switch" next to your entry door. It's meant to reduce the battery drain of RVs while they're on display.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Near Annett’s Mono Village, Bridgeport, CA
Posted: 01/12/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the battery? Cleaned the connections?
myface
Posted: 01/12/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Winnebago Brave SE 2001 29A. Battery have power. Check the connection. The one switch, by the door is AUX Battery and I try to turn on and off. Nothing. I can hear a solenoid clicking on front.
enblethen
Moses Lake, WA
Posted: 01/12/20 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like battery disconnect is in off position.
Should be switch normally by the entry door to energize battery disconnect relay. Some Winebagos have battery disconnect behind the entry step. As I remember that is wwhere your batteries are. There is a small metal plate to remove to show disconnects.
Sounds like blown fuse. Some battery disconnect relays have fuse mounted to them.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
myface
Posted: 01/12/20 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
My batteries are under the step. I look everywhere and can not see any master switch. I trace the Positive wire(big)from battery and could not find any switch. Could it be that the relay give up?.
myface
Posted: 01/12/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I run jumper cable to control box and have 12V in coach. Lost connection somwhere between battery and control box.
enblethen
Moses Lake, WA
Posted: 01/12/20 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it could be relay or blown circuit breaker.
Go to Winnebago website and locate the electrical drawing for your rig.
Option is to follow the positive cable.
Relay could be in the battery control center depending on which one you have.
myface
Posted: 01/12/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
The relay is in front of vehicle. I can hear it clicks. Will the 10gauge wire be enough for temporary jump?
Ranger Smith
Wherever the rig is parked
Posted: 01/12/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
There is usually a fuse right at the battery. It is like a 250a or 300a fuse. That could have popped
Where we are now
Amateur Radio Operator WW1SS . . . Yaesu FTDX 101D Acom 1000, Icom 7100
Steve and Joy
2011 Itasca Meridian 40u . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
