RV.Net Open Roads Forum: Class A Motorhomes: SOLVED No 12V
enblethen
Moses Lake, WA
Posted: 01/12/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Very temparary.
Circuit breaker at or on circuit would normally sized according wire size leaving batteries going to the converter. I would guess closer to a 30 amp.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
myface
Posted: 01/12/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
No fuse at battery
enblethen
Moses Lake, WA
Posted: 01/12/20 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Check the 12 volt DC panel for a BAT fuse.
enblethen
Moses Lake, WA
Posted: 01/12/20 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Locate the relay that you hear click with aid of a helper. Check voltage on each side testing on large posts. When closed, the voltages should be the same. When open they should show different voltages.
If the voltages are not the same the relay is bad. Make sure test it in both positions.
dodge guy
Bartlett IL
Posted: 01/12/20 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Follow the battery wire. There should be a 30A circuit breaker in line along that wire. It probably tripped.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Executive
Posted: 01/12/20 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
This could help identify your problem...Dennis
Battery
This was posted at 1PM today.
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
gatorcq
Arizona
Posted: 01/13/20 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Did he not say, 12 Vdc with Generator - No 12Vdc when Generator off OR does he mean NO 12Vdc on shore power. So how about the transfer switch
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
enblethen
Moses Lake, WA
Posted: 01/13/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
OP has another post that clarifies some questions.
Other post
myface
Posted: 01/13/20 08:19am Link  |  Quote  |  Print  |  Notify Moderator
The battery switch, by the door, is going to solenoid. The solenoid work. I check the voltage with on and off. Somewhere I lost connection to control box. Are you suspecting that my charger may have something to do with?.
myface
Posted: 01/13/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I do not have a shore power. Just generator to charge my batteries. My computer runs of 1000W inverter.
