RV.Net Open Roads Forum: Class A Motorhomes: SOLVED No 12V
enblethen
Moses Lake, WA
Posted: 01/13/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
There must be a fuse or circuit breaker between batteries and battery control center.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ksg5000
Oregon
Posted: 01/13/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Google "auto reset circuit breaker" - doesn't look much like a fuse/breaker and easy to overlook. If you discover one check for continuity.
Kevin
myface
Posted: 01/13/20 10:26am Link  |  Quote  |  Print  |  Notify Moderator
8 gauge black wire going from solenoid to control box. I try to "chase" that wire, but it is too much cover. I will run 6 gauge wire from battery to control box with fuse(15A) in line. That will temporary give to me 12V until I find the brake. Having "hard time" locate wiring diagram for my coach.
enblethen
Moses Lake, WA
Posted: 01/13/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Wiring diagram 1 40 amp under dash pod.
wiring diagram 2
Hope this helps.
Make sure you turn coach (aux) switch on/off without engine running for testing. You could be hearing the charge relay and not battery disconnect. 1/0 red wire goes to charge/emergency start relay then to battery disconnect.
Locate model of battery control center and post.
You could use larger fuse for your temporary connection maybe as large as 30.
myface
Posted: 01/13/20 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen you are my savior. the breaker is under the dashboard. I would never guess. Thank you very much.
myface
Posted: 01/13/20 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
All fuse are under the dashboard. My electric mirror do not work. I was looking for the fuse and found today. Thank you Winnebago for the confusion - next time hide better.
enblethen
Moses Lake, WA
Posted: 01/13/20 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
You are welcome!
Take your time fix one thing at a time. You will pick up more experience and be able to help others!
myface
Posted: 01/13/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
As former truck driver, I have no problem driving this vehicle, but the rest of it I need to learn, just like I learn about boats 6 years ago. I have experience how to fix a boat and drive. Now the motor home. I have the owner manual, but no diagrams. I got 3 month to get to shape and then - hit the road.
Thanks again.
enblethen
Moses Lake, WA
Posted: 01/13/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I would take a little "spare" time and locate make and model of your appliances. You can then down load manuals. Bryantrv.com has many. He is member here.
Winnebago has many of you drawings on their website.
I save many of the manuals to a thumb drive. We carry a laptop in the MH.
Make a list of your problems, prioritize them.
Don't hesitate to ask here. Don't be upset about some posts.
myface
Posted: 01/14/20 04:58am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
