RV.Net Open Roads Forum: Class A Motorhomes: 1997 Headlights on Bounder
 > 1997 Headlights on Bounder
MrWizard
Traveling
Posted: 01/13/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I know the halogen bulbs can be replaced
But
Can the headlight be disassembled to clean the inside of the lenses
I've done the exterior clean and restore, with the mguires plastic polish and UV protection spray
They are clear not yellow, but there are spots on the inside of the lenses
Radiate The Happy
1997 F53 Bounder 36s
ScottG
Bothell Wa.
Posted: 01/13/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
They're usually glued together.
Most of the time they used headlight assemblies from a popular model current vehicle. Looking at pics of 1997 Bounders (yeah, I've got time on my hands!) your's look like they may be from a 1995-ish Ford Ranger pickup.
I've had great luck with aftermarket, factory style replacements. Often you can get a set from eBay for well under $100 and they're perfect! Example
There may even be some embossed righting on your lights that reveal their origin.
Cheers,
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Johno02
Lexington, TN USA
Posted: 01/13/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Look at buyrvlights.com. You can get a complete replacement set. I replaced mine, and was very pleased with the results and cost.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
SidecarFlip
SE Michigan
Posted: 01/13/20 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
But
Switch the Crest toothpaste and WD40. Cannot help on replacements.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
enblethen
Moses Lake, WA
Posted: 01/13/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
My rig has Ford pick up headlights.
Only way to really fix interior of headlight problems.
Ford pickup headlight assemblies
* This post was edited 01/13/20 06:32pm by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
sehunter
Rancho Murieta, Ca.
Posted: 01/13/20 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced mine about four years ago with these Ford headlights and very reasonable compared to calling Fleetwood. They are at least a 1/3 brighter.
Amazon
Stan
2008 Bounder
38P, W24, 8.1L, 3 Slides
2019 tow dolly hydraulic brakes
Chum lee
Albuquerque, NM
Posted: 01/15/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
But
Just replace them. The problem is not only the lenses degrading, but, the reflectors (inside the lamp assembly) degrade also. Turn the headlights on at night and look at the back side of the lamp assembly. If you see light going out the back of the lamp assembly, well . . . . . that light is supposed to go out the front.
Chum lee
