RV.Net Open Roads Forum: Travel Trailers: 1st trailer... septic hookup questions
 > 1st trailer... septic hookup questions
RoyF
Fayetteville Arkansas
Posted: 01/14/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
We will assume that my wife and I are (more or less) average. We routinely go one week between dumps with a 40-gallon black tank. So not more than 20 galons per person per week seems like a reasonable figure for black tank usage.
(I say "not more than" because our tank is unlikely to be completely full when we dump.)
Even though we follow recommended practices (plenty of water, dump only when full), we managed to have a toilet blockage recently. (It was the fifth-wheel's eleventh year of use.) We put a hose down the toilet with nozzle set to high pressure to break up the obstruction. (We discarded the hose and nozzle, of course.)
ken56
Tennessee
Posted: 01/14/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Seeing it will be parked long term pick up a water spray wand to put down the toilet once a month or so to thoroughly rinse the tank out. Because the tanks will not experience the agitation of being towed down a bumpy road the wand will help rinse out anything that settles on the bottom of the tank. My trailer has a tank rinser built in but I still do this also and it gets a lot of paper and clumps that tend to stick out. Oklahoma still has freezing weather so think about preventive measures for cold temps too.
CavemanCharlie
Storden,MN
Posted: 01/14/20 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
On many RV's (but, not all ) You can shut the water off, hold the toilet valve open, and then look down the toilet to see how full the black tank is.
Hammerdown3512
Oklahoma
Posted: 01/14/20 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I don't know the exact size of the tank shed my trailer will be delivered at beginning of next week. I bought it from a place 2hrs away. I wenti saw it in person but didnt ask about tank capacities. Its a 40ft that sleeps 6 so i imagine its pretty big tanks. Its just me 4 nights a week and 4 kids 9 and under 3 nights a week.
1320Fastback
Vista, Ca
Posted: 01/14/20 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
If you leave any of the valves open you run the risk of bugs, gas fumes and god knows what else getting into your tank and your RV.
Keep the valves shut unless draining.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
CFerguson
on the road
Posted: 01/15/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
As you are in OK, don't forget to insulate your hose.
opnspaces
San Diego Ca
Posted: 01/15/20 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Kids will add a potential for some complications. Start early with explaining that it only something they ate or toilet paper can go down the toilet. If you have any girls let them know that personal hygiene products are never to go down the toilet. Start now with a trashcan in the bathroom by the toilet while the kids are still young. You want them (boys and girls) to get used to not throwing kleenex hair from the shower, tampons etc down the toilet.
I second the suggestions to not leave any valves open. You will quickly learn how often you need to dump the tanks. Since you're trailer is not going to move you won't have the benefits of the contents of the tank sloshing around. So in that case you need more water in the tanks before dumping so things can get washed out.
Of course this is not set in stone. The world will not come to a stop if you dump the tanks more or less often. It is after all a tank full of stuff, not a carefully monitored and controlled biosphere. So for instance, if you are going to take the kids to the beach or lake, dump the gray tank before you leave so they can take showers when you return. You can do this even if you dumped the day before.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
trail-explorer
NM
Posted: 01/15/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hammerdown3512 wrote:
How do you know when tanks are full?
Is there no tank monitor display panel?
Bob
ktmrfs
Portland, Oregon
Posted: 01/15/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Absolutely!! remember, there are NO p traps in the lines to the dump opening.!!!! More than once someone has left the grey tank valves open and either (a) wonders where the bad smell is coming from or (b) others nearby wonder where the bad smell is coming from. Well, no p trap= sewer gas
2011 Keystone Outback 295RE
MarkTwain
Northern, Ca. , USA
Posted: 01/15/20 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
Keep black and gray valves closed all the time until your black tank is 3/4 full. Empty your black tank 1st. then lack your gray tank. Close your black tank and fill it with the back tank from the shore line but use a seperate hose and use this hose only for the black flush. Add 15 gallons and then open the black tank again to flush out the black tank again. then close both the black and gray tank valves again. There is some black tank cleaning materials that help.
