RV.Net Open Roads Forum: Why are my batteries water overflowing during charging?
 > Why are my batteries water overflowing during charging?
mrad
Prineton, MN
Posted: 01/13/20 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I brought in my two deep cycle batteries from my boat and the one from my camper for winter storage. I check all of the water levels and had ended up adding some distilled water to each, bring it to just under a 1/4" from the top. I had just purchased a new schumacher 15A/3A auto charger. So far all three batteries have overflowed during charging. Did I get a bad charger? What else coull be the cause of this? My old chargers fan went out last summer so it could no longer handle long charges so I had to purchase the new one. I have never experienced this problem before.
Any Ideas?
https://www.amazon.com/Schumacher-SC1280........G7TRAY&psc=1&refRID=084BGV1W7V93NMG7TRAY
philh
Belleville MI
Posted: 01/13/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
you over filled them. To the bottom of the ring with full charge
wolfe10
Posted: 01/13/20 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
At this point all we can do is SPECULATE.
What is charging voltage after a couple of hours (i.e. float voltage)?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
mrad
Prineton, MN
Posted: 01/13/20 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
By the ring, do you mean fill them to the bottom of the cylinder the caps snap on?
azdryheat
Tucson, AZ
Posted: 01/13/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
x2
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
3 tons
NV.
Posted: 01/13/20 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
All I can add is that I had to toss two near new smaller Schumacher maintainer chargers because they ruined two of my AGM batteries...
time2roll
Posted: 01/13/20 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
You should fill them to 1/4" below the split ring that extends down into the cell. Just touching the bottom is absolute max.
Actually the electrolyte will expand as the battery is brought from low charge to full charge. Best to just verify the plates are covered and top off (as above) after the battery is fully charged.
OK there is a possibility the battery is shorted and excessive bubbling has forced the electrolyte out through the cap.
675w Solar pictures back up
CA Traveler
The Western States
Posted: 01/13/20 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
I would remove the excess ligquid from each battery placing it in a glass jar for that battery maybe to added back later. Then take the batteries to a good battery shop and have them load tested. Load testing involves first fully charging the batteries before doing the load test. Be aware that the battery acid is already diluted some because of the overfill and overflow, hence the liquid is no longer nominal.
If the batteries are OK it might be worthwhile adding some acid back to achieve the correct liquid balance. Perhaps check with the battery shop first and get their input on the overfill. BTW A auto parts store is NOT a good battery shop.
After the load test if they pass then they need to be recharged.
2014 Grand Cherokee Overland
Bob
River-Runner
Oregon
Posted: 01/14/20 12:28am Link  |  Quote  |  Print  |  Notify Moderator
I've just gone from two Trojan T-105 wet cells to four Trojan T-105 AGM's. My first AGM's, so I am in learning mode. I'm currently using a Battery Minder charger w/ AGM mode when in storage. I have a progressive dynamics 9200 series converter/charger installed from the factory I'll use when plugged in on trips..
Why do you say the chargers ruined your chargers, wrong voltage?
Thanks.
2112
Posted: 01/14/20 03:38am Link  |  Quote  |  Print  |  Notify Moderator
Read the watering section half way down this page:
https://www.trojanbattery.com/tech-support/battery-maintenance/
Water should always be added after fully charging the battery. Prior to charging, there should be enough water to cover the plates.
2013 KZ Durango 2857
