RV.Net Open Roads Forum: General RVing Issues: Residential Refrigerator – Good or avoid?
 > Residential Refrigerator – Good or avoid?
Page of 5
Dutch_12078
Winters south, summers north
Posted: 01/19/20 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Dtank wrote:
Retired Firefighter huh!..[emoticon]
You need to explore the fire hazard potential - and if you're still happy with your gas/electric - add fusible link actuated extinguisher in the rear of the fridge compt.
You might want to take a look at the flammability of the R600 refrigerant seeing more and more use in residential refrigerators...
R600a (CARE 10) Isobutane
Dutch
2001 GBM Landau 34' Class A
philh
Belleville MI
Posted: 01/19/20 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
How much power does a residential fridge typically draw. Some of reported it quickly drains batteries, and others have suggested it's really not that bad.
navigator2346
texas
Posted: 01/19/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
A residential refer will typically draw 3 amps ac. That equates to about 30 amps dc. But you have to remember that the refer does not run 24/7.
Cummins12V98
on the road
Posted: 01/20/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
"DEPENDS" cold out not much, hot out a lot!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
DrewE
Vermont
Posted: 01/20/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Take a walk through Home Depot or Lowes or someplace like that and look at the energy star stickers in some comparable residential fridges. If you divide the yearly energy consumption by 365, you'll get the daily energy use in kWh, under their test conditions. 1 kWh or maybe a bit more seems to be about what I saw in my last quick walkthrough.
1 kWh roughly equates to 100 Ah from the DC system. Whether or not that quickly depletes your batteries depends on how large a battery bank you have and what sorts of systems you have to recharge it (such as solar).
My opinion: if you're basically always staying at places with electric hookups, or at places where you'll be running the generator most all the time anyway for other reasons, a residential fridge will be no problem with any installation. If you're camping without hookups or boondocking, you need to pay much closer attention to the battery bank size and probably would want a decent solar installation so as not to have to run the generator for a few hours daily. If you'll be camping without hookups in the woods or a cave, a residential fridge would seem to be a liability.
Dutch_12078
Posted: 01/20/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Here's the label on our residential fridge. The duty cycle is typically about 25%:
Smokeyrr
WEEKI WACHEE, FL
Posted: 01/24/20 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the fridge in our RV with a residential unit. I went with the Magic Chef 10.1CF. Good thing was that it fit through the door with no problems. I don't boondock either but I won't say that I never will. LOL Cost wise a replacement Dometic installed was about $1,400. The Magic Chef from Home Depot $389.
pnichols
The Other California
Posted: 01/25/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
I've read a lot in these forums on residential versus RV refrigerators.
It seems that the main unhappiness with RV refrigerators occurs in the larger cubit foot size ones - that are in large motorhomes, TTs, and 5'ers. Our small motorhome has only a 6.3 cf Norcold RV refrigerator in it, with 5 coldness settings.
It does just fine in the hottest weather set on only 3 or 4, out of it's 5 coldness levels. We can easily get by 2-3 weeks before having to reshop for refrigerated food.
* This post was edited 01/25/20 07:26pm by pnichols *
Phil, 2005 E450 Itasca Spirit 24V
CavemanCharlie
Storden,MN
Posted: 01/26/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
That could be !! My 20 foot TT has a smaller propane fridge. The type where the freezer compartment door is inside of the fridge. The freezer is rather small but, it works for me. I am just a weekend camper and I don't need to bring that much frozen food with me. My propane fridge works well and I like it.
time2roll
Posted: 01/26/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have read posts where 500 watts solar will not keep up with a residential fridge when off grid. May need to go 800+ watts or plan to use a generator at times.
Otherwise everyone seems to brag on how much better the residential fridge functions. In transit is not an issue.
675w Solar pictures back up
Page of 5
