RV.Net Open Roads Forum: General RVing Issues: Residential Refrigerator – Good or avoid?
 > Residential Refrigerator – Good or avoid?
Page of 5
rk911
Wheaton IL
Posted: 01/14/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
a64armt wrote:
OK, we are on the hunt for a 5er’ to not only facilitate a relocation but we are planning on getting back into RV travel and adventure. We are looking at some used units, including several Lifestyle RV’s. I see a few with “residential refrigerators” and inverters. I am curious what the thoughts are from experienced owners. I have considered some differences, these include;
Plus – More room, usually ice and water in door, more visually appealing, probably better for full time operation / reliability
Minus – Expensive to purchase / replace, required removal of slide to replace, requires narrow range of models for fit and application.
Thoughts?
OJ
depends on the type of camping/RVing you plan to do. mostly boondocking: traditional RV fridge. mostly full hookup parks and resorts: residential.
your cons are not necessarily accurate. replacing an an RV fridge can be more $ than a resi depending on size. removing the doors on our resi allows it to be removed from our MH.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
ScottG
Bothell Wa.
Posted: 01/14/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Rich and I don't believe this is a black or white issue. It all depends on what is going to work best for you, which could be either one.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
CavemanCharlie
Storden,MN
Posted: 01/14/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I sometimes go dry camping with o electric and I love my gas fridge ! But, it is one of the older ones that seemed to work better then the new ones. I never have any trouble keeping things cold.
My brother has a nice new 5th wheel and his gas fridge won't stay cool on gas even during the day while traveling down the road.
bikendan
Camano Island, Wash.
Posted: 01/14/20 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
We dry camp a lot and would NEVER have a residential fridge.
We don't need that much fridge space, for just two people.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
DrewE
Vermont
Posted: 01/14/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
A good solar system will take care of a residential fridge when you don’t have electric hookups. Once they are up to operating temp they require very minimal energy to operate.
Last time I quickly looked around, modest fridges at Home Depot were around 1 kWh/day or a little less per the Energy Star labels. That's not a lot of power all things considered, but it's perhaps a bit more than very minimal energy too. It's certainly not beyond the reach of a decent but not extravagant solar setup assuming you are camping in an area where solar power is a reasonable option. (Solar power when out in the woods doesn't work quite so effectively!)
My Dometic RV fridge has so far worked pretty much flawlessly. Plenty of people have had good experiences with residential fridges. Both systems can work out fine, or not do well at all if improperly/poorly installed and set up.
valhalla360
No paticular place.
Posted: 01/14/20 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
If you are mostly on shore power, residential is fine.
If you are away from shore power a lot, propane makes a lot of sense. You can make residential work but it gets expensive adding an inverter, upgrading the battery bank and a charging system to keep up with the fridge.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Dtank
Posted: 01/14/20 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Retired Firefighter huh!..[emoticon]
You need to explore the fire hazard potential - and if you're still happy with your gas/electric - add fusible link actuated extinguisher in the rear of the fridge compt.
"Space" - Refrigerators are available in all sizes, whether gas/elect or electric only (residential).
BTW - NEVER -say- NEVER, ROTFL!!
nightshift
Vancouver, BC
Posted: 01/14/20 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
X2 We boondock 4 weeks at atime. Even with 600w of solar and 2 l16 batteries, a residential would drain us.
valhalla360
No paticular place.
Posted: 01/14/20 11:52pm Link  |  Quote  |  Print  |  Notify Moderator
Ummm... I've seen 3 RV fires. All 3 were electrical related. I know it's a common cause of RV fires.
Are you planning to rip out the electrical system in your RV?
bikendan
Posted: 01/15/20 02:49am Link  |  Quote  |  Print  |  Notify Moderator
i consider the fire hazard potential as minimal. Are you a firefighter?[emoticon]
We love dry camping too much, to give in to having a residential fridge. Haven't seen any RV fridges as big as the residential fridges. So they aren't available in ALL sizes.
Page of 5
