RV.Net Open Roads Forum: Tech Issues: Solar charge current
 > Solar charge current
DarkSkySeeker
Freestone, California
Posted: 01/14/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I've read about solar charging systems, and am impressed when the owner boasts of the current generated. What I don't understand is how a system that generates 20-50+ amps doesn't fry the batteries. In these high current systems, is the charge being passed through a bank of batteries in parallel so each battery sees reasonable current?
There is something special about camping in an RV.
2oldman
Ca
Posted: 01/14/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
The controller handles the current that's needed.
DarkSkySeeker
Posted: 01/14/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Whazzat? The controller knows how much current to pass depending on battery capacity?
2oldman
Ca
Posted: 01/14/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, that's why it's there.
DarkSkySeeker
Posted: 01/14/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
So - here's a silly example.
If I had a big array and one battery, the charge controller would limit the 50+ amps to perhaps 4 amps to the one battery?
red31
Bryan
Posted: 01/14/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Battery and/or bank of batteries will accept all they can until a voltage set pt is reached. Then the controller limits power to the battery to maintain the set pt voltage.
High current into a small bank will cause the bank's voltage to rise quicker and then be limited by the constant voltage set pt.
time2roll
Posted: 01/14/20 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Same way your 55 amp converter does not damage the battery or your 130 amp alternator does not burn out your vehicle battery.
Just like any charger... the voltage is controlled and as the battery comes up to the same voltage the amps taper off to zero at full.
675w Solar pictures back up
2oldman
Ca
Posted: 01/14/20 11:03am Link  |  Quote  |  Print  |  Notify Moderator
That's what a decent controller is designed to do. As said above, they're just like any other charger.
BFL13
Victoria, BC
Posted: 01/14/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
No, the controller controls the battery voltage. The controller has an amps rating. Some controllers have a current limit so they don't over-heat by amps going above the controller's rating..
The battery itself controls the amps going into it by its "natural acceptance rate", which is higher at higher voltage. It accepts more amps at 14.4v than at 13.6v.
Current to the battery depends on whether it is an MPPT or PWM controller. With PWM you can get the panel's Isc rating worth of amps, but with MPPT you get the controller's output watts divided by the battery's voltage at the time. The battery doesn't care where its amps are coming from though.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
twodownzero
NM
Posted: 01/14/20 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
My controller knows how large my array is and what kind of batteries (conventional lead acid) are attached to it. I can adjust the charge voltages as well. I expect my batteries will last many years since they are never dead or even close.
