RV.Net Open Roads Forum: Tech Issues: Solar charge current
 > Solar charge current
2oldman
Ca
Posted: 01/14/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
twodownzero wrote:
My controller knows how large my array is and what kind of batteries (conventional lead acid) are attached to it.
My Outback controller doesn't ask how big the array is, but it does ask for the battery bank size in ah.
MrWizard
Traveling
Posted: 01/14/20 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
DarkSkySeeker wrote:
2oldman wrote:
Yeah, that's why it's there.
So - here's a silly example.
If I had a big array and one battery, the charge controller would limit the 50+ amps to perhaps 4 amps to the one battery?
No..if it did, I would change controllers
DOES your converter limit charge to 4 amps
DOES YOUR ALTERNATOR LIMIT CHARGE TO 4 AMPS
It would take days to recharge the batteries
Charge rate is applied voltage versus battery resistance
My converter can do 75 amps
My previous RV I installed over 600+ ways of solar panels
Radiate The Happy
1997 F53 Bounder 36s
pianotuna
Regina, SK, Canada
Posted: 01/14/20 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
During the day time, if I want to harvest some free power, after the battery bank is full, I'll use the inverter to run the water heater.
Regards, Don
2oldman
Ca
Posted: 01/16/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Obviously not. I assumed he meant 'during the course of charging' it would get to a point where the current was limited.
Not that he'd actually want to set something like that.
beemerphile1
Ohio
Posted: 01/16/20 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
To visualize it, think of it this way; the current isn't pushed into the battery, the battery sucks it in. When the battery is full and stops sucking, the current stops.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
ktmrfs
Portland, Oregon
Posted: 01/16/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
under ideal conditions most flooded cell lead acid batteries will have maximum cycle life if the intial charging current is limited to about C/10 C=rated AH. However, you can still get very long life cycle even charging at an initial C/2 to C/4 rate. The charge rate will decrease as the battery bank gets near full charge, starting to taper at when the battery is about 70% charged.
So... a initial 50A charge rate isn't excessive for a couple of 12V or pair of 6V golf cart batteries.
what controls the current going into a battery is the source voltage, battery voltage, battery internal resistance, the current the source can supply and the charging algorithm.
On a deeply discharged battery on initial charge the charging current will be limited by either the source max current or the battery internal resistance. Generally the max source current is the limit.
* This post was edited 01/18/20 09:55am by ktmrfs *
2011 Keystone Outback 295RE
2oldman
Ca
Posted: 01/17/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Almot
out there
Posted: 01/19/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Max current accepted by battery depends on how deeply it is discharged. Could be a lot more than 4 amps for one 100AH battery - at the beginning. Then current drops as it's nearing the Full. Then it jumps up again when you turn some powerful device On - solar outputs the energy directly into the device.
Controller controls volts, differently on different stages of charging. When it controls volts, amps (= charge flowing into battery) are also affected.
As long as it doesn't interfere too much with RV aerodynamics, there is no penalty for having a bigger solar than you think you need, but there are often benefits.
