RV.Net Open Roads Forum: General RVing Issues: Propane vs Electric Heating
 > Propane vs Electric Heating
avarusbrightfyre
San Diego
Posted: 01/14/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
So I know this will vary widely by location, but I live in Southern California and I'm curious to know which would be the more cost effective solution. Electricity out here is expensive, but I think propane is too. Does anyone out here in SoCal have any experience with both that can shed some light on the cost of each? If it's about the same, I'll probably invest in some space heaters so I don't have to lug the tank to refill so often.
2019 34' Minnie Plus Travel Trailer
San Diego, CA
rk911
Wheaton IL
Posted: 01/14/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
we're always on hookups so we mainly heat with electric...fireplace and a small portable space heater. we have a new heated mattress pad for cool nights. we don't usually use the rooftop heat pumps due to the noise. other than the first few nights of our snowbird trek we avoid traveling in very cold weather.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 01/14/20 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Are you living in your RV full time and staying in one place where they're metering your electrical use? If they aren't metering it, then use the electric heaters.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
avarusbrightfyre
San Diego
Posted: 01/14/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I'm currently living full time in a permanent metered location.
Second Chance
Wherever...
Posted: 01/14/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
When we spend extended periods in SoCal, it's at a big Escapees park. They have on-site propane with VERY low prices. With metered electric, propane is significantly more economical - but I have to take a 30 lb. tank up to the filling point every week or two if the weather is cool.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
2020 Solitude 310GK-R on order (with MORryde IS)
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Flute Man
Payson, Arizona
Posted: 01/14/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
I have found over the years it is just about a trade off with the use propane or electric. I am on all electric right now with Propane as a back up. I would say use whatever is most convenient.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Eric&Lisa
Scappoose, OR
Posted: 01/14/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Electric when on-grid (pay per night camping). Propane when off-grid dry camping.
If you are running on a meter, then it becomes a math problem. Electrical: Wattage of heater, hours run per day, cost of a kilowatt/hr, determine a dollar amount for daily usage. Propane: Cost to fill the tanks, estimated days per tank, determine a dollar amount for daily usage. One will be cheaper. My bet is on electric will be cheaper.
Ultimately you need to plug in the numbers and do the math. It will be different for all of us.
-Eric
Eric & Lisa - Oregon
'97 Silverado K2500, New HT383 motor!, Airbags, anti-sway bar
'03 Lance model 1030, generator, solar,
avarusbrightfyre
San Diego
Posted: 01/14/20 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
-Eric
Ok, so I need to make sure I'm doing my math right. Most of the space heaters I'm seeing are 1500 watts. I estimate 6 hours per day (cutting on an off from 6 pm to 6 am). It might be less, but I'm not sure. 1500 watts x 6 hours = 9 kwh. Current price per kwh for electric is $0.28, which puts me at about $2.52 per day, or $35 for two weeks.
My average price to fill a tank is about $18 every 10 days or so, or about $25 per 2 weeks, so it appears on the surface that propane is cheaper.
I guess now the question is am I willing to spend $20 per month for the convenience of not having to cart the tank around every 10 days. My first guess is probably yes, lol.
Lynnmor
Red Lion
Posted: 01/14/20 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Calculators like this will help you decide: Fuel Costs
Bob/Olallawa
Kitsap Co, WA/Bullhead City AZ
Posted: 01/14/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you are staying in one spot for a while, check with the propane place and see if they will place a larger tank and fill it onsite.
Welcome to my home, that door you just broke down was there for your protection not mine.
