RV.Net Open Roads Forum: Class A Motorhomes: engine antifreeze
Old Blue
New York USA
Posted: 01/14/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
2007 Holiday Rambler with a 325 cummins engine, what type antifreeze should I use in the radiator? Pulled some out of the overflow container and it seemed to be a green color. This antifreeze has never been changed.
Thanks
Bill
Bill
36 Holiday Rambler
Harley Rider
Yosemite Sam1
Under the pines.
Posted: 01/14/20 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Drain the overflow tub and the radiator and replace it with regular anti freeze from Walmart.
Or have Walmart do it for you.
wolfe10
Posted: 01/14/20 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
If this is the Cummins ISC engine, that is very bad advice. Even for the B, it is not what Cummins recommends.
Read coolant specs in your Cummins manual or your chassis manual.
There are basically two kinds of approved coolants for diesels:
1. Low silicate for diesel with added SCA (Supplemental Coolant Additive)
2. The new generation long life coolants for diesels.
With a Cummins, I would sure look at the Fleetguard coolants, as that is Cummins in-house brand. If you ever need work at a Cummins shop, they will have the same coolant as you are using.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Yosemite Sam1
Under the pines.
Posted: 01/14/20 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I should have concluded that it's a diesel with the Cummins engine.
Blaster Man
Posted: 01/14/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
As noted above, you need coolant for a diesel, not a gasser.
2014 American Eagle
gbopp
The Keystone State
Posted: 01/14/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
That's just scary.
Oceano Dunes, CA
Posted: 01/14/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend following the advice from Cummins.
Ranger Smith
Wherever the rig is parked
Posted: 01/15/20 03:06am Link  |  Quote  |  Print  |  Notify Moderator
Not on my worst day.
You have either a Fleet Guard fully formulated which has the SCA's in it or you have an OAT coolant depending on the year of your rig. A call to Freightliner can tell you which they put in when built.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6600 & Maestro , K3, P3 and KPA 1500,Icom 7100
Steve and Joy
2011 Itasca Meridian 40u . . . 2016 Ram 1500 4x4 Toad
Cooper ... The Doodle,
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
Wherever I happen to park
Posted: 01/15/20 05:04am Link  |  Quote  |  Print  |  Notify Moderator
Note that the quoted text below applies to ALL engines with only a name change:
"Read coolant specs in your Cummins manual or your chassis manual."
This is always the best advice. be it a Cummins, Cat, Detroit Diesel or Chevy or Ford gasser.. Read the manual. NO manual visit the factory store (A Cummins dealer in this case)
The different colors tend to Suggest (not dictate) a type of anti-freeze. Some of them do not mix well with others. Some can cuase real issues if they are put in the wrong engine.
Chevy for a time used a special "Lifetime" coolant on their engines. (I do not know the color)
But you want to stick with the same type the factory put in if you can.
NOTE: you need not buy it at the Cummins shop but find out what kind it is there.
Home is where I park it.
azrving
Oatman
Posted: 01/15/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
X2 on being very careful on getting the correct coolant. My 2014 ctd pickup uses OAT which looks orange in the reservoir yet is actually purple. The CTD SUPPLEMENT warns of engine damage if the wrong coolant is used. Every auto parts store will try to sell me the wrong thing, only the dealer has had the correct stuff so far.
I would never listen to Walmart and auto parts stores
