RV.Net Open Roads Forum: Truck Campers: Mopeka Products
 > Mopeka Products
Geewizard
E. Washington
Posted: 01/16/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
I think this is better:
Dometic LPGC10 LP Gas Checker
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
220W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
ford truck guy
Pennsylvania
Posted: 01/17/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I had used that for years and was not thrilled with it, then I heard about these - Trauma
I have had it 1 year and so far its really accurate.
Me-Her-the kids
2015 Ford F350 SD 6.7
2020Redwood 3991RD Garnet
deltabravo
Spokane, WA
Posted: 01/17/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
breeves2245 wrote:
I thought it would be a hassle to manually check the tank, but it's really not much trouble.
How do you manually check the level in the tank?
I've had numerous RVs since 2003 and have no known way to manually check the level in the tank that "isn't much trouble"
2015 Nash 17k (bought pre-owned 5/23/18)
breeves2245
Northwest Arkansas
Posted: 01/18/20 04:27am Link  |  Quote  |  Print  |  Notify Moderator
I just release the strap and partially raise the tank without taking it out and I get a feel for the level. Would prefer the sensor was accurate, but it really is not much effort involved.
tmartin000
Washington
Posted: 01/18/20 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Trauma unit and its the bomb! I push the rubber spring tip to anywhere on the tank, it beeps red or green....if its Red, its out to that point...if its green, then its full to that point. Keep moving up if you wish.
I mark an erasable blue tic at the filled-to spot (date it) and keep doing that each day for a few times...soon you KNOW your true use and the gizmo is superfluous.
I used 2.5 iterations of that stupid Topeka ****...They parts either broke or fell apart and were "no longer supported". I was done 3 years into buying into that BETA program.
I espouse to the keep it simple program.
AnEv942
CA
Posted: 01/19/20 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
One of those items that seems either loved or hated.
Made short video of use. youtube. Course Camper batteries need changing, I get about a year.
When too lazy to get up and push monitor button or open phone I can ask Margaret to check on her phone[emoticon]
Our tanks are at shoulder height in camper- even empty not 'easy' to lift.
* This post was edited 01/20/20 10:19am by AnEv942 *
Our camper projects page
deltabravo
Spokane, WA
Posted: 01/20/20 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Mine too, so pulling them out to do a "weight check" to judge the estimated level isn't going to happen.
I've had the Mopeka sensors for two years and they've been flawless other than needing to change the batteries about every 8 months
* This post was edited 01/20/20 08:30am by deltabravo *
brholt
Seattle
Posted: 01/21/20 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I went through two of them when I gave up and got the Trauma. The battery cage in the Dometic broke in both.
tmartin000
Washington
Posted: 01/22/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Funny, mine is 2 years old and on the same battery. Works like new down to 19 degrees last Xmas vacation. [emoticon]
Geewizard
E. Washington
Posted: 01/22/20 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Likewise. Mine keeps working.
 > Mopeka Products
