RV.Net Open Roads Forum: Travel Trailers: Mount trailer tires yourself at home?
 > Mount trailer tires yourself at home?
cougar28
Lowell,AR USA
Posted: 01/15/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago yes but especially not now! My son has a automotive shop next door to me. I get a really good discount. ??
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
fitznj
nj
Posted: 01/15/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
My local tire shop charges $20 to unmount/mount/balance a tire;
At that price, it's not worth doing it myself.
Gerry
hugemoth
Bend
Posted: 01/16/20 03:26am Link  |  Quote  |  Print  |  Notify Moderator
The $39 tire machine I bought from Harbor Freight many years ago has saved me many hundreds of dollars over the years. I haven't paid a tire shop to mount tires for about 20 years. For balancing trailer tires I mount the wheel/tire on the hub then find the heavy spot and add weight to the opposite inside until it rotates without stopping in the same position every time.
deltabravo
Spokane, WA
Posted: 01/16/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I would never even think of attempting to mount any sort of car, truck or trailer tire at home, unless I had a tire machine.
I don't even do my motorcycle tires...
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Mike134
Elgin
Posted: 01/16/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
It's a little harder than mounting a bicycle tire. Then you need to hit it with lots of air pressure/volume to seat the beads. That's the most likely time you'll get hurt.........
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Tvov
CT
Posted: 01/16/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
KMLsquared wrote:
...I read a bunch about balancing trailer tire and came to the conclusion most are not...
Yes, most equipment trailers that travel mostly local, lower speed roads don't "need" to have tires balanced.
But... for my camper, which I tow on highways / interstates at the appropriate speed, I want them balanced. And it is usually very inexpensive, especially when included in a package price of buying new tires.
2008 F-250 CrewCab 5.4L,
GrandpaKip
Flat Rock
Posted: 01/16/20 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I have the tire shop add balancing beads when changing tires.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Lynnmor
Red Lion
Posted: 01/16/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I do the same. When balancing the tires that way, do it when servicing the wheel bearings. Clean the bearings completely and apply some light oil. Don't install the seal and make sure there is no brake drag and it spins completely free. Mark the wheel and stud to insure it will be always replaced in the same position. You can actually get the balance of the assembly much better that the tire shop with their fancy balance machines that only balance the tire and may not locate the wheel exactly the same as your hub.
I now use an old refurbished on the vehicle balancer. I do find it humorous whenever the balance issue is discussed, because few are ever checked and few are balanced as well as the crude methods mentioned above.
Posted: 01/16/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
This is one of the sillier questions asked recently.
What are the savings? Whatever the tire shop charges.
Can you do it at home? Sure, if it’s worth it to you to bust tires by hand.
Still have to go to the tire shop to balance the wheel unless you don’t believe in that, or are attempting to balance with beads/BBs.
Posted: 01/16/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
That’s a great story if you have literally the entire day to “mount and balance “ a set of tires.
How’s that work on your truck or car?
Your time must be worth a lot less than most to go through all that trouble.
And fwiw, balancing to the hub is an act of diminishing returns or more accurately futility.
Aside from the moment of inertia being considerably less due to the small hub/ brake diameter compared to the much larger diameter tire, it becomes useless once you rotate tires unless you re balance each rotation.
