RV.Net Open Roads Forum: General RVing Issues: Zoning Law
 > Zoning Law
cxr133
Sunny Cali
Posted: 01/15/20 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Guys,
i tried doing a search here and a google search and cant seem to find the information i need. I own my house in SoCal , Northridge Area.
in my backyard i have a RV pad and it is off an alley.
Are they laws against having a sick relative living in a 5th wheel fulltime? and running electric, water. Are there zoning law against this?
The only thing i did find was that i can maybe get a sewer hookup if i label it a clean out plug, correct?
alot of my neighbors have done garage conversions. but i need my garage space.
Thanks in advance
valhalla360
No paticular place.
Posted: 01/16/20 01:58am Link  |  Quote  |  Print  |  Notify Moderator
Zoning is typically done locally.
Go down to your local city office and ask for a copy of any zoning laws related to RVs and/or living in them.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
midnightsadie
ohio
Posted: 01/16/20 03:47am Link  |  Quote  |  Print  |  Notify Moderator
if your not in a crowded area give it a try .
JRscooby
Indepmo
Posted: 01/16/20 04:50am Link  |  Quote  |  Print  |  Notify Moderator
In my area, if you are in violation of zoning laws you will be notified, and have time to correct. If it takes a month for somebody to notice, the you have a month to move...
cavie
Posted: 01/16/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Your local town government has a web site with all the answers you need.
edbehnke
North America (from Michigan)
Posted: 01/16/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
call them
eddie and sandie
3402 Montana 2013
Ford F350 2015
Campfire Time
Wisconsin
Posted: 01/16/20 06:53am Link  |  Quote  |  Print  |  Notify Moderator
As said you will need to find out what the local laws are. Your alderperson may know already know the answer or be able to point you in the right direction. Often you can do this if you live in a rural area sometimes just getting a permit for it. But in more populated areas it is considered a dwelling if used in this way. Often the best you can do is call the police dept and say someone is staying by you for a week or two. Usually you can't go beyond that.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid, 2008 GMC Sierra SLE1 Crew Cab Z71
Dutch_12078
Winters south, summers north
Posted: 01/16/20 07:09am Link  |  Quote  |  Print  |  Notify Moderator
In my upstate NY location, the "RV Dump Station" label issue was related to the local code defining it as a commercial device requiring commercial septic specifications that my residential system wouldn't meet. Labeling it a "4 inch cleanout", which is what the fitting actually is, satisfied the rules and the building inspector regardless of how it would actually be used. It was the building inspector that actually made the label change on the septic system plans I submitted.
Dutch
2001 GBM Landau 34' Class A
ItsyRV
Desert SW
Posted: 01/16/20 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your actual Zoning designation. Most of the straight "R" designations in your county does not allow for RV use outside of a "temporary" use. Staying in the RV on your property over the weekend appears to be acceptable, but longer and you may be in violation of Zoning, Building and Fire codes. However, your local AHJ will be the proper source.
Usually, if it's behind a fence, out of sight, you may get away with it, but it only takes one neighbor to make the call and you could have trouble. So, keep your neighbors happy!
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
wnjj
Cornelius, Oregon
Posted: 01/16/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
In many places staying long term in an RV isn’t allowed, however right now much of the west coast states have a housing shortage and officials are looking the other way.
 > Zoning Law
