RV.Net Open Roads Forum: Adding USB and 12v outets to my 2 RVs
 > Adding USB and 12v outets to my 2 RVs
deltabravo
Spokane, WA
Posted: 01/16/20 06:50am Link  |  Quote  |  Print  |  Notify Moderator
I have a lot of photo equipment and other things that need charged when I'm out adventuring.
In my truck camper I switched things around part way through the project and ended up with a 12v battery monitor up near the control panel, and 12v / USB down below.
Here's how I did it in the truck camper.
In my Nash 17k, I connected the 12v and USB to the stereo power lead, which is right next to where I mounted them.
12v and USB in my Nash 17k
* This post was edited 09/09/20 06:50am by deltabravo *
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
coolmom42
Middle Tennessee
Posted: 09/08/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
Yep, I really do own 2 RVs, the ones in my signature line.
Nice video. Something I plan to do!
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
IowaFrogFarmer
Iowa
Posted: 09/09/20 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I cheated and used this to add usb charging ports to my rig.
Charter Good Sam Lifetime Member
2020 Coahcmen Clipper Cadet 17FQC
2015 Jeep Grand Cherokee Laredo
1954 Wife
coolmom42
Middle Tennessee
Posted: 09/20/20 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
How does one go about locating, accessing, and identifying the wiring to something like the stereo?
The inside entertainment setup has some cubbies around it that would provide a good location for chargers. There is also an outside unit that I never intend to use (TV, speakers) and would like to use the power supply to that system, too.
bigorange
Tucson, AZ
Posted: 09/20/20 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
Do those usb outlets work on 12v power or require AC power?
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
BarabooBob
Baraboo, WI
Posted: 09/21/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I added three 12 volt outlets to my TT. The first one is right inside the door on the side of the overhead cabinet. I got the power for this on from the light above the sink. The next on is above the passenger side dinette seat at the rear of the TT. I got the power for this on by tapping into the stereo power feed. The third outlet is above the driver side dinette seat. To power this one, I ran a channel up the corner of the TT to conceal the wires and got the power by tapping into a line coming out of the converter.
At the same time that I added these outlets, I added LED lights above the seats of the dinette to make reading easier. I used the same power supply that ran the 12 volt outlets.
We use these almost daily to charge camera batteries when we don't have shore power.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
bpounds
Sophmore Brain...
Posted: 09/23/20 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I put this in a couple years ago.
I used this fixture, which connects to any 12vdc source.
12v USB wall fixture
They also have one for 110vac source. Surprisingly the one with a built-in transformer is less $.
110vac USB wall fixture
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
JimK-NY
NY
Posted: 09/23/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
I guess we all have different needs. What I seem to use the most are 12 v charging ports. Adding a single one over by the sink would not be at all ideal for my needs. Instead I added 3 ports on the side of the dinette were my wife usually sits and another 3 on my side of the dinette. With 6 additional ports we can use car chargers for running our laptops, charging cellphones, charging camera batteries, etc. When necessary I plug in a small inverter for charging batteries where I have not found a 12 v alternative to 110 charging. The small inverter also has a couple of USB ports but I don't think I have ever used one.
