RV.Net Open Roads Forum: Tow Vehicles: rough country Lift good or bad?
Search only in Tow Vehicles
 > rough country Lift good or bad?
Bedlam
PNW
Posted: 01/17/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
There are suspension lifts and body lifts:
A suspension lift will put everything higher except the axles and is generally preferred for real off road use. This will give you more problems when towing because of the tall receiver, sharper drive line angles and higher center of gravity.
A body lift leaves the frame and power train at stock height but uses spacers to raise the body higher. Although this is not as good for offroading, it will allow you to run taller tires with less hitch compensation required and the CG will stay closer to stock.
My opinion is that tow vehicles should not be lifted but for those that do, using a body lift will create less issues.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Posted: 01/17/20 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
What he said^.
But most importantly, if you do a body lift on your truck, you’ll look like your rednek cousin Joe Dirt from down n the holler! All you’ll need is the mullet and a pack of Winston lights to complete the look. Still cheaper than a suspension lift !
deltabravo
Spokane, WA
Posted: 01/17/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Rough country lifts are on the bargain end of the spectrum.
Ditto.
There's a reason the word Rough is in their name. That's the ride quality you get with a low end lift kit.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 01/18/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
EgoLifts! Check them out on the web.
Lynnmor
Red Lion
Posted: 01/18/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
The purpose of the lift is ________________________ ?
Me Again
Posted: 01/18/20 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I think I covered that on the post ahead of yours^.
FishOnOne
The Great State of Texas
Posted: 01/20/20 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Then what's holding you back?
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
Me Again
Posted: 01/20/20 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Fish your sig line still says 2012 Ford!
Posted: 01/21/20 12:38am Link  |  Quote  |  Print  |  Notify Moderator
Lotta $ and some craftsmanship into those trucks.
Maybe some guys "thing" isn't Edsels, Hudsons and Hupmobiles either....
Naw you're right, they're stereotypical bro dozers. But that Ram would be pretty sweet if the skinny jeans tires got swapped for the right size donuts.
kellem
Shenandoah valley,VA
Posted: 01/23/20 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
I lifted my truck and went with 35's and with stock 3.73 gears, it's now a marginal tow vehicle but **** does it look good.
Oh to the topic:
Rough country lifts are affordable.
