RV.Net Open Roads Forum: Fifth-Wheels: Solar panels and battery cut off
 > Solar panels and battery cut off
irish31790
Reading, OH
Posted: 01/16/20 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new 5er. It came with solar charger - Go Power brand. I’ve only had it a couple of weeks and haven’t had a chance to do much with ie because of the holidays and weather. My question has to do with the batteries and the solar chargers. When I put the rig in storage I hit the battery disconnect. I assumed the solar charger would still charge with battery cut off. But when I returned the batteries were dead. I guess I shouldn’t use the battery cut-off??
Mr. B
Reading, OH
2020 Cedar Creek Hathaway 34IK
2019 Ram 3500 Tradesman SRW Diesel
Morro Bay, CA
Posted: 01/16/20 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Guess not. Do you have a wiring diagram? Did you check at the battery for any charging? Does the controller indicate charging? What’s the total solar watts? Which controller do you have?
Morro Bay, CA
Posted: 01/16/20 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Seems as if it comes with “solar prep” but not a solar system. Did you get a solar package?
laknox
Arizona
Posted: 01/16/20 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the solar is wired in such a way that it doesn't charge when the disconnect is off. Same with shore power; if the disconnect is off, batteries won't charge. I'd leave the disconnect on, OR re-wire the solar direct to the batteries.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
jdc1
Riverside, Ca
Posted: 01/16/20 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of weeks with the batteries disconnected should not happen,even if the solar is not directly connected. I would start by testing those batteries. I'll bet the place you bought the rv had it connected to the shore power while you checked it out?
Morro Bay, CA
Posted: 01/16/20 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, a couple of weeks disconnected shouldn’t drain them.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 01/16/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Battery must not be cut off from solar, its good bye controller if that is the way it is wired, check and be sure solar is wired to controller and direct to battery.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
pianotuna
Regina, SK, Canada
Posted: 01/17/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
panels-->switch-->controller-->fuse-->battery bank-->cut off switch-->loads.
Never have the panels send power to the controller without the battery connected.
Regards, Don
irish31790
Reading, OH
Posted: 01/18/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Looks like I have some homework to do! Thanks for the ideas gang.
justme
Posted: 01/20/20 11:06am Link  |  Quote  |  Print  |  Notify Moderator
That is very good advise because when the solar charger is unloaded with the panels connected the voltage from the panel to the controller exceeds the rating of the semiconductors in the charge controller-- thus destroying the controller.
