RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel tires
 > 5th wheel tires
Page of 10
Nomad
Barnegat, New Jersey
Posted: 01/17/20 10:44am Link  |  Quote  |  Print  |  Notify Moderator
What are considered the best tire for 5th wheels today
Have a Cedar Creek weighing 11,700 wet and it is time for a change
romore
Okanagan valley British Columbia
Posted: 01/17/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
The well known brand name tires with the ST designation should serve you well. Stay away from the cheap brands offered on line, these 'China bombs' will cost you a lot of money and grief. Also make sure the manufacturing date is current, some 'new' tires peddled at a discount will be old stock.
ford truck guy
Pennsylvania
Posted: 01/17/20 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
BEST is always a figure of speech, OR personal opinion...
MOST talked about here lately are:
Goodyear G614 (16") --- Goodyear G114 (17.5")
and the BIGGEST talker - Saliun.. that tire seems to have a TON of traction in the market now with great results
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
BB_TX
McKinney, Texas
Posted: 01/17/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have 80 psi wheels or 110 psi wheels? The G614 and Sailun are 110 psi tires.
If by wet you mean loaded for travel then the Michelin XPS Ribs are great tires for lighter weight trailers. For that weight you should have something in the range of 9,000 lbs on the tires. The Goodyear Endurance ST is a relatively new tire that seems to get good reviews. I believe it is an 80 psi tire.
azdryheat
Tucson, AZ
Posted: 01/17/20 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Any tire from China is junk, no other way to describe them. I put Michelin LT truck tires on my first 5th wheel and later on my current toy hauler (XPS Ribs). No tire problems in 8 years. No need to put 110 psi tires on your trailer as it doesn't weigh enuf to justify the higher pressure. Get quality, non-Chinese tires and you'll do fine.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Two Hands
California's Central Coast
Posted: 01/17/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
We were very happy with Michelin and Goodyear on our fifth wheel and current motor home. They came as a result of a blowout on our fiver with a nearly new China bomb.
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
guidry
Texas Cajun
Posted: 01/17/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
G rated tires! take your pick on which one, it's the load range that will help you. I can't believe I didn't change over years ago!
RoyF
Fayetteville Arkansas
Posted: 01/17/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
My 2008 Hitchhiker II at 12,000 lbs wet is about the same weight as yours. For the first six years I used LT load range E tires with a good reputation and still had blowouts. For the past six years I have used Carlisle ST load-range F tires and have no problem of any kind with them. (These were all replaced with new ones last year.)
One bit of evidence is not proof, of course, but I'm going to continue using one load-range higher than what is required.
FrankoToo
New Braunfels, TX
Posted: 01/17/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
What size tires are currently on the rig, how many miles a year do you plan to put on them, what are the axles rated at? By 11,700 wet, is that the gross weight of the trailer? Before downgrading, my prior FW TH was 18k gross but because we were only weekend warriors traveling short distances, I could not justify going to a G rated or LT tire. Went with Maxxis at the time. No problems what-so-ever. Currently looking at GY Endurance for my smaller, lighter TT. Just my opinion.
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
rhagfo
Portland, OR
Posted: 01/17/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
We run LT’s on our 12,500# 5er no issues.
Page of 10
 > 5th wheel tires
