RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel tires
 > 5th wheel tires
Page of 10
ScottG
Bothell Wa.
Posted: 01/17/20 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
azdryheat wrote:
Any tire from China is junk, no other way to describe them.
Or sure there is, but the pesky forums rules preclude using the most accurate terms. [emoticon]
FWIW, so far I am happy with my Goodyear Endurance tires.
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
laknox
Arizona
Posted: 01/17/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
Do you have 80 psi wheels or 110 psi wheels? The G614 and Sailun are 110 psi tires.
If by wet you mean loaded for travel then the Michelin XPS Ribs are great tires for lighter weight trailers. For that weight you should have something in the range of 9,000 lbs on the tires. The Goodyear Endurance ST is a relatively new tire that seems to get good reviews. I believe it is an 80 psi tire.
A less expensive alternative to the XPs are the Bridgestone Duravis R238. For only 12k lbs, a G tire is a bit of overkill, IMO.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
flifisher
Central Coast of California
Posted: 01/17/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Two years after purchasing my Jayco Eagle FW, I up sized the wheels from 15 - 16" to run Light truck tires. I ran BFGoodrich Commercial TA's, load range E for the past eight years. Had a blow out in September and purchased a new set of Goodyear Endurance trailer tires. I have put 6,000 miles on the new tires and have not had any issues. I believe the tire failure was due to leaking metal valve stems and extremely hot weather. Happy with both of my tire selections to date and agree to stay away from the cheap china tires if at all possible, if it's within your budget.
2018 Ram Laramie Mega Cab Off Road 2500 4X4 6.7 CTD and a Super Gluide hitch
2008 Jayco Eagle Super Lite 30.5 RLS
fj12ryder
Platte City, MO
Posted: 01/18/20 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Scott
Wow, apparently my China-made Sailun tires never got the memo. Six years 20,000+ miles, and still look and ride great. Couldn't be happier, and cost about 60% less than some other brands. Win, win.
Howard and Peggy
"Don't Panic"
mtofell1
Oregon
Posted: 01/18/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
My 5th is similar weight and my research came up with Carlisle or GY Endurance. Weight wise check your rims and if they are good for 80psi you should be good with E rated at about 2800# each. Mine stock came with D rated 2580 each stock which is cutting it a bit close IMO. The E rated also have a higher speed rating which was nice. Not that I really go over 65 but it's nice to know I'm not right up against the rating.
garyp4951
TN
Posted: 01/18/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
With 33" axle spacing, I would suggest the GY Endurance in your current size, or the Bridgestone R238 in a 245-75-16.
I have not seen an unmounted Endurance, but I had Duravis 250's before, and they are a heavy steel tire.
Cummins12V98
on the road
Posted: 01/18/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Bottom line that RV does NOT come close to needing "G" tires.
I guess the ENDURANCE "nay-sayers" have decided 3 full years on the market has proven these tires to be worthy as they seem to be silent now.
Do a search for "ENDURANCE tire failure". You won't fine any that are not road hazard.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
mtofell1
Oregon
Posted: 01/18/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Agreed - It may not even be an option if OP has 15" wheels. Mine (similar weight) came with 15" and the highest rated I could find are E. Not that I wanted higher than E - I was just curious. A good quality E rated tire is plenty for an 11K 5th wheel.
Limit4
Festus Missouri USA
Posted: 01/18/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Here's what I know for sure. Maaxis for three years and 0 problems.
83trekker
calgary,ab,canada
Posted: 01/21/20 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
How do you know how much weight your rim can carry so i know if i can upgrade my 15" rim to E load?
Page of 10
 > 5th wheel tires
