MFL
Midwest
83trekker wrote: mtofell1 wrote: My 5th is similar weight and my research came up with Carlisle or GY Endurance. Weight wise check your rims and if they are good for 80psi you should be good with E rated at about 2800# each. Mine stock came with D rated 2580 each stock which is cutting it a bit close IMO. The E rated also have a higher speed rating which was nice. Not that I really go over 65 but it's nice to know I'm not right up against the rating.
How do you know how much weight your rim can carry so i know if i can upgrade my 15" rim to E load?
It should be stamped on the back of rim. What size and rating are your tires you have. If your wheels are 6-bolt, with D rated tires rated at 2540, likely they can handle the E rated at 2830 lbs at 80 psi.
Jerry
83trekker
calgary,ab,canada
My rims are 6 bolt and have maxxis load range d on them right now 65 psi.
edited 01/23/20 10:25am by an administrator/moderator *
MFL
Midwest
You should be good to go with the E-rated, just have tire mounting shop confirm, and maybe up grade the valve stems, if going to 80 psi.
Jerry
Cummins12V98
on the road
The FACT is D or E tires will take the exact inflation to carry the same load. Inflating E tires to 80 when 65 is plenty will cause worse ride, center tire wear and further stopping distance. E tires at 65 will be a stronger tire at 65 than a D at 65.
Personally with the quality of the ENDURANCE I would stick to the D tire if you are not overloading it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
83trekker
calgary,ab,canada
Well my 5th wheel is 29ft and 10000lbs fully loaded and run 15" maxxis load range d psi65 and no.probelm in around 7 years on the same set of tires.
Limit4
Festus Missouri USA
83trekker wrote: Well my 5th wheel is 29ft and 10000lbs fully loaded and run 15" maxxis load range d psi65 and no.probelm in around 7 years on the same set of tires. when I bought my new Maxxis tires I was advised to run them no more than 5 years because of going bad from the inside. That advice came from a tire dealer I trust and also from this forum.
83trekker
calgary,ab,canada
I am replacing mine this year, my axle is slightly off as it burned 2 of the tires off, but i did take 7 years for it to happen. Called our largest axle place here and to re align it its the cost of a new axle. I am not going to bother fixing it. The way it wears the tires down, by the time they are worn down its time to replace the tires anyways.
MFL
Midwest
Not sure of your backing situation, but I have to back into my drive, from the same direction every time, when returning home. This has caused some visible wear to passenger side outside edge of tires, due to backing at a fair angle on concrete, causing scrub on that edge.
I don't think you can get D rated Endurance in your tire size, or like above poster mentioned, that would be my choice. I also agree with above mentioned wt carrying ability of D&E at the same psi. However, for scrub, and heat reasons, if changing to an E-rated tire, I still recommend adding the extra 15 psi to them.
Jerry
edited 01/23/20 10:26am by an administrator/moderator *
Retired JSO
North Georgia Mountains
Durb wrote: G rated tires on a 11,700# trailer? Talk about massive overkill. My trailer has an 11,500" GVWR and could have been optioned with passenger tires. I tow with 16" LRE tires and have around a 50% safety margin while towing at approximately 10,500#. I towed with Towmax tires (China bombs) for four seasons with zero issues. I'm currently running Goodyear Endurance. The tires tow the same, longevity and speed ratings are the only criteria I used.
I was running E rated Uniroyal LT tires on a 2004 Sandpiper, 12253 Cat weight, and blew 2 of those. Switched to Sailun G and no other problems no way is it overkill.
Cummins12V98
on the road
If you are running full 110 inflation on a rig that only needs 80 it is overkill.
If airing based on weight carry on.
