RV.Net Open Roads Forum: Truck Campers: Lance Umbilical Mod
 > Lance Umbilical Mod
Freep
Wisconsin
Posted: 01/17/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Lance truck campers come with a proprietary umbilical that has 8 gauge power cables built in. They recommend rewiring your truck so that you have 8 gauge to the alternator. I have found that this is a good recommendation due to power consumption of the fridge and charging of the batteries via your alternator.
I have recommended using their cable for a while but I have had serious issues with their plug slipping. It's terrifying to be driving down the highway in the middle of the night and have an 18 wheeler blast their horn at you because you have no tail lights. I had this happen enough times that I decided to go a slightly different route. I researched plugs and cables and found no alternative that had 14 gauge lights with 8 gauge power and I definitely didn't want to go back to the standard 7 way plug.
So I split the umbilical into two cables and two plugs.
After a lot of research I settled on these two waterproof plugs with solid latches. The Lance plugs rely on a flimsy latch built into the cover. Never again.
https://smile.amazon.com/gp/product/B0797MG7Q3
https://smile.amazon.com/gp/product/B07XZMB3PK
Since I was rewiring from battery to TC I decided to go with 6 Gauge just to make sure I had plenty of electron flow.
https://smile.amazon.com/gp/product/B01MD1ZGKO
Then I needed decent cable for the lights.
https://smile.amazon.com/gp/product/B0791JL4VT
I was going to combine both cables in heat shrink cable tubing but later decided against it. But I did use some heat shrink tubing to stiffen the cable near the plugs on the truck side, along with some silicone.
One thing I was worried about with these plugs is the tiny mounting holes and small bolts. It was going to be a pain to install directly into the bed so I made some mounting plates from white house electrical plates.
Here is the cable prior to hitting the heat gun on the sleeve.
Mounted in the bed
Full gallery here.
* This post was edited 01/17/20 08:54pm by Freep *
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
ScottG
Bothell Wa.
Posted: 01/17/20 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Cant see your images [emoticon]
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Freep
Wisconsin
Posted: 01/17/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
Ah figured it out.
* This post was edited 01/17/20 09:08pm by Freep *
deltabravo
Spokane, WA
Posted: 01/17/20 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Nice looking upgrade.
I upgraded my system with Mega overkill charging leads
2015 Nash 17k (bought pre-owned 5/23/18)
specta
utah
Posted: 01/18/20 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
What year did Lance go to their own umbilical cord??
Kenny
2011 Chevy 2500 HD 6.0L 4wd Regular cab.
What real trucks really look like.
6580 lb truck 10540 fully loaded
tmartin000
Washington
Posted: 01/18/20 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am 100% going to copy this! Excellent idea!
* This post was edited 01/22/20 09:05am by tmartin000 *
bighatnohorse
Gig Harbor - Cave Creek
Posted: 01/21/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Freep:
Thank you for your excellent post with photos.
Unfortunately, others have turned it into a barf mess that should be cleaned up.
You might want to re-post it on the Lance Owners Forum where the post will be appreciated.
Thank you for your effort.
2014 Lance 1181
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
burningman
Seattle, WA USA
Posted: 01/21/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
There’s a better thing to do.
Remove the RV style 7-flat-pin connectors and install big-truck style 7-round-pin plugs and connectors. They’re much more robust, reliable, and they accept heavier gauge wire. The good heavy duty ones will take 10-gauge.
8-gauge on the ground.
(Ground is bigger because there are a lot of 12v circuits, running lights, turn and stop, charging, etc that all supply +12V and all return through the same ground.
* This post was edited 01/21/20 03:28pm by burningman *
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Freep
Wisconsin
Posted: 01/24/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I looked at those but they have a similar flaw to the lance plug. The latch is a function of the cover and the plug can pop out when driving over rough terrain. What I initially wanted was a plug that would screw into the receptacle but I didn't find a pair that were as heavy duty as the plugs I found. I really like the plugs I got.
Eric&Lisa
Scappoose, OR
Posted: 01/24/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Freep wrote:
...I have recommended using their cable for a while but I have had serious issues with their plug slipping. It's terrifying to be driving down the highway in the middle of the night and have an 18 wheeler blast their horn at you because you have no tail lights.....
Nice upgrade. A solid fix.
That said... I have never had my factory Lance cable come unplugged. I don't think there is a systemic issue to address.
-Eric
Eric & Lisa - Oregon
'97 Silverado K2500, New HT383 motor!, Airbags, anti-sway bar
'03 Lance model 1030, generator, solar,
