RV.Net Open Roads Forum: General RVing Issues: Sewer Pipe Question
 > Sewer Pipe Question
Kountryguy
Emery,SD
Posted: 01/19/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
When flushing my toilet, I glanced down the pipe and saw some kind of off white gel like substance growing on the pipe. I took a stick and then a brush and scraped it off.
Now about a month later, same thing. Any ideas what it may be or what is causing it?
midnightsadie
ohio
Posted: 01/19/20 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
tooth paste??
Kountryguy
Emery,SD
Posted: 01/19/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
No, we spit in the sink.
cavie
Posted: 01/19/20 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
toilet paper.It needs to be in the water to desolve.
goducks10
There
Posted: 01/19/20 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Are you filling the tank before you poop?
Kountryguy
Emery,SD
Posted: 01/19/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
If you are asking about the toilet bowl, yes, I fill it about half full before using. If you are asking about the tank, I put about 10 gallons in before using.
naturist
Lynchburg, VA
Posted: 01/19/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
My guess is toilet paper that is growing some sort of fungus. Just a guess. But are you using RV TP or regular household TP? And any tank treatment?
Kountryguy
Emery,SD
Posted: 01/19/20 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Using a tank treatment, one of the digester ones, TP goes in a can.
time2roll
Posted: 01/19/20 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you really want to know you will need to pull it up instead of push it down.
675w Solar pictures back up
Boon Docker
Posted: 01/19/20 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
The next time add some bleach to your brush before doing the scraping. That should get rid of the slime for good.
