RV.Net Open Roads Forum: Travel Trailers: Question on inner bearing grease seals
 > Question on inner bearing grease seals
plasticmaster
Home
Posted: 01/20/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
When replacing the inner bearing grease seals, does it matter what brand the seal is? The reason I ask is because I bought National brand seals today at my local parts store for almost $12 each and now I'm finding seals online for less than $3 each. That's a substantial difference. Is the expensive one really any better. This is for my boat trailer, but this question would apply to my travel trailer as well since they both use double lip grease seals. Thanks.
ScottG
Bothell Wa.
Posted: 01/20/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Some seals are designed to be used with the EZ lube or in the case of marine stuff "Bearing buddys" style grease system and are built to take the pressure (in theory..) created during the greasing process. Those seals cost more.
If you don't use that "feature" then the cheaper, more common seals work fine for RV's but for a boat trailer, I'd get the better ones becasue they have a tighter seal.
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Nv Guy
Reno NV
Posted: 01/20/20 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the better seals are worth it. As mentioned before they are better able to handle the pressure and vacuum that develops in the hub cavity due to heat cooling cycles. Really, it it worth $ 36.00 to have one of those $3.00 seals fail while on the road?
1320Fastback
Vista, Ca
Posted: 01/20/20 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
National is a name brand and a manufacturer for others. I'd pay the $12 for that quality anyday.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
opnspaces
San Diego Ca
Posted: 01/20/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed on the quality for a trailer that is going to dunk the warm bearings under water.
If your trailer has the bearing buddy caps then the more expensive seals are hopefully double lip seals which are required. The cheaper seal might be only a single lip seal which will leak with the bearing buddy system.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Jackathan
Nebraska
Posted: 01/20/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I worked in industrial maintenance at one of the largest meat slaughter and packing facilities for 10 years. National and Chicago Rawhide seals are what was used in those extreme environments. From 100 below 0 degree blast freezers to 120 degree and up kill floors. I would stick with National or CR instead of no name brands. If you are worried about cash, try the cheapies. Maybe they will hold up? I'll pass. If you're broke down in the middle of nowhere, use what you can get!
Posted: 01/20/20 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
I'll echo the same sentiment for quality seals and bearings.
Although I'll admit, a "quality" oil bath hub seal lasted about 500 miles on our boat trailer and I stuffed a $5 Autozone seal in it (in the parking lot, stupid oil hubs, grease could've waited until getting home or next year.....) and that was 2 years and a couple thousand miles ago.
I'd still buy better quality given the choice.
theoldwizard1
SE MI
Posted: 01/21/20 04:11am Link  |  Quote  |  Print  |  Notify Moderator
Take the National part number and look it up on Amazon and Rock Auto. You will be surprised at the price.
Flute Man
Payson, Arizona
Posted: 01/21/20 04:33am Link  |  Quote  |  Print  |  Notify Moderator
Are you really willing to risk your boat trailer for a few dollars?
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
ford truck guy
Pennsylvania
Posted: 01/21/20 05:34am Link  |  Quote  |  Print  |  Notify Moderator
National seals all the way for me . . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
