RV.Net Open Roads Forum: Tow Vehicles: timbrens
Search only in Tow Vehicles
 > timbrens
Page of 5
GWolfe
Kansas
Posted: 01/23/20 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I had them on my half ton, replaced them with air bags. Like IdaD said, the softer suspension in my half ton did not work well with the Timbrens. I don't know if the gap was right but it wasn't a comfortable ride when empty. I had the proper gap according to their instructions but maybe my springs were getting weak because the Timbrens would engage with almost every bump I would hit. This was on my old truck, I went straight to airbags with my current truck.
I had no complaints with the Timbrens when I had my ATV in the bed and my camper hooked up, it was the unloaded ride I couldn't handle.
2005 Sun-Lite Eagle
2011 Silverado
Aka the breeze
Anywhere
Posted: 01/23/20 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for the feedback... How about lower Stable Loads? I see they now have stainless steel version. not sure how they work?
Old Days
Colorado
Posted: 01/23/20 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I really like the lower stable loads on my truck they take the sway out of the ride.
frankwp
Calgary, AB, Canada
Posted: 01/23/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
I got talked into putting Timbrens on 3 of the work vans. They did keep the vehicles more level with a heavy load, but that's the only good thing I can say about them. They effectively reduce suspension travel and all 3 had significantly rougher ride. I'd go with air bags, or just have better springs installed.
I had the Timbrens removed from one of the vans & had another leaf installed in the spring pack & it was a big improvement. As I recall, the added spring was not much cost difference than having the Timbrens installed.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Retired JSO
Northeast Florida
Posted: 01/23/20 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I have 2 sets used on 2 different F250 trucks. Unloaded ride is rough. If anyone would like to own them, they are free to those visiting NE Florida.
Second Chance
Wherever...
Posted: 01/23/20 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I installed them on our previous truck (2013 Sierra 2500HD D/A). They did not affect the unloaded ride and did exactly what was needed with 3,000 lbs. pin weight on the truck - stopped the bottoming out on bridge transitions, etc. The rig also felt more stable with less bouncing. I was very happy with them.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS and disc brakes
Solar
(Previously 4 yrs, 9 mos full-time in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
N-Trouble
NorCal
Posted: 01/23/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
They work great on my 2012 Duramax. Would buy again in a heartbeat.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
cummins2014
Utah
Posted: 01/24/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
What is the reasoning getting away from air bags ??. Have ran two sets of aftermarket air bags Firestone ,and Airlift. They both have held up well, and worked equally well.
Aka the breeze
Anywhere
Posted: 01/24/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Looking for a change ??
Tired of airing up before a tow, and airing down for all other driving.. getting lazy I guess?
Cummins12V98
on the road
Posted: 01/24/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
From everything I have read you will NOT be happy going from bags to Timbrens.
With my 11 HO DRW RAM I ran 5psi unloaded with stock like ride. With 4,500# pin added the pressure went up to 30psi and was enough to keep the truck "LEVEL" and setting on overloads as it was designed to be. Rode GREAT!!!
I had in cab controls with separate side controls to make minor adjustments.
Adding bags and Bilstein's made the loaded ride AWESOME!
Too many "THINK" they need to air bags to have trucks rear when loaded at unloaded ride height. BAD way to go.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Page of 5
 > timbrens
