RV.Net Open Roads Forum: Who can help me pick out a 600 watt solar sytem?
 > Who can help me pick out a 600 watt solar sytem?
mromberg
escondido,ca,usa
Posted: 01/24/20 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Ok gang.......I'm trying to put together a 600 watt solar system for my soon to be purchased 2017 Class A Fleetwood Bounder. The coach is equipped with 4 100ah 12 volt batteries and a 2000 watt inverter. It also has a Samsung residential fridge. I also would want a battery monitor included.
So....would anyone be willing to help create a parts list, preferably on amazon, to include the cables, fuses, etc? Perhaps it could also serve as a starting point for others in my same boat....overwhelmed by all the choices.
Budget ~$1000 - $1200
Thanks!
Kern County, CA
Posted: 01/24/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Your budget may need some augumentation. WindyNation's 400 watt system is $720 but you'd also need two extra panels at a hundred each. With wire, connectors, DiCor etc. I believe you'd be over. IMO 400 battery amp hours would be on the low side too.
https://www.windynation.com/MPPT-Polycrystalline-Solar-Kits/Windy-Nation-Inc/WindyNation-WNI-400-Watt-4pcs-100W-Solar-Panel-Kit-Trakmax-MPPT-40-A-Solar-Charge-Controller/-/342?p=YzE9NDc=
theoldwizard1
SE MI
Posted: 01/24/20 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
The Victron Energy Battery Monitoris one of the best you can buy. There are several models, depending on what "additional" bells and whistles you want.
On the panels them selves, the first thing you need to decide is what physical size. "Standard" home panels are 2m x 1m (over 6' by over 3') and 72 cells. These are difficult to handle it you are on a roof. You can easily find 1/2 size panels, 1m x 1m and 36 cells, easier to handle but more connections. The other consideration is monocrystalline vs. polycrystalline. Mono are more efficient but cost more. 200W per square meter is consider "good".
I do not have enough experience to recommend brands beyond the battery monitor. For the charge controller, you probably can not go wrong with any of the name brands.
At the moment, the Chinese built panels have a large tariff. Some distributors are getting around this by purchasing from suppliers in other parts of Asia. There are some solar panels being built in South Korea.
theoldwizard1
SE MI
Posted: 01/24/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
This is a classic case of a RV manufacture trying to "save a buck" !
Four 6v golf cart batteries (size GC2) will give you about 420 AH of storage and well likely last longer and are the same price or less than 12V "dual purpose" batteries. AGM batteries are nice (zero maintenance) but expensive.
Personally, I would want an inverter/charger/auto transfer switch instead of a converter/charger and stand alone inverter. Maybe a bit more expensive, but easier to wire and MUCH easier to use !
If you plan to boondock a lot, a true DC refrigerator is more efficient than a residential unit. You probably will not find one as large and if you are on "shore power" most of the time you are camping, it does not matter.
IAMICHABOD
Sunny So Cal 90713
Posted: 01/24/20 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I know this is not what you asked for but I thought I might throw it out there.On of our members,a moderator, had a system installed by This Guy and was very pleased with what he got. The price is a bit over your budget but that is the installed price.
Link to the thread mentioned here
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
mromberg
escondido,ca,usa
Posted: 01/24/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'll give it a read.
mromberg
escondido,ca,usa
Posted: 01/24/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to give these batteries a test before I change them out. But, yes, AGM's are on the list.
Old Days
Colorado
Posted: 01/24/20 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
I just looked on amazon a 600 solar kit from Renogy is $1446.00 so you may have to increase your budget. Or buy china solar panels.
Crushedstang50
Wichita, KS
Posted: 01/24/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
This kit is usually about $850 on amazon but is on sale for $530 right now. Buy two more panels to get you to the 600 watts and your good. I have been watching it for almost a year on amazon. This is the cheapest I have seen it.
Renogy 400 Watt 12 Volt Off Grid Solar Premium Kit with Monocrystalline Solar Panel and 40A MPPT Rover Controller/Mounting Z Brackets/MC4 Adaptor Kit/Tray Cables Fuse set /MC4 fuse https://www.amazon.com/dp/B07CTKT56Y/ref=cm_sw_r_cp_taa_yO3kEb039328N
Hopefully the link works......I have not posted a link before!
2007 Keystone Outback 23rs
2016 Ford F150 Platinum. Max tow, 6.5 bed, 3.5 ecoboost
mromberg
escondido,ca,usa
Posted: 01/24/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
This looks promising. I sent the guy an email as his installed prices seem fair.
