FishOnOne
The Great State of Texas
Enjoy...
Link
edited 01/25/20 07:19am by FishOnOne *
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
SidecarFlip
SE Michigan
Those clowns need a real job.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Travlingman
Jonesborough, TN
That is pretty impressive for the Ford running 3.55 gearing. The 10 speed seems to be doing its job.
Don't understand why you would start downhill with 30K behind you and not have exhaust brake on.
2017 F-350 King Ranch DRW
2014 Landmark Savannah
blofgren
Surrey, B.C.
SidecarFlip wrote: Those clowns need a real job.
??? ![doh [emoticon]](http://www.rv.net/sharedcontent/cfb/images/doh.gif)
Thanks for sharing, Fish. The new Ford is certainly impressive!
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
LITEPHIL
AZ
They showed the GM at a point and mentioned it was doing 45 mph but the tach was at 2500 rpm. With all those gears there should have been a gear to put it in the 3500-4000 rpm range. Same for when they tested the 6.6 GM gas. I know,if floored either of those GM trucks would have down shifted another gear.
Clowns
2019 Chevy RST Silverado 1500
1954 Chevy 3100 Carryall 4x4
2002 Sandpiper T22
04 FXDL Harley
Cummins12V98
on the road
Will be nice to see how the measly 400/1000 with 4.10's RAM does with it's ancient outdated 6 speed AISIN.
Very easy to have ZERO brake applications if one chooses running cruise control.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
4x4ord
Alberta
Cummins12V98 wrote: Will be nice to see how the measly 400/1000 with 4.10's RAM does with it's ancient outdated 6 speed AISIN.
The new Ram has already run up against the Duramax 10 speed towing 16000 lbs. The Ram and GM had identical times of 8:24.
click
edited 01/25/20 12:20pm by 4x4ord *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
ksss
Eastern Idaho
This test seemed a lot more haphazard than what they have done in the past, particularily on the down hill portion. There is no question the Ford dominated the run up the hill. Looks like in this case the Ford actually performed like you would expect given its power advantage. GM clearly is going to have to find some more power to compete with the Ford 6.7 on this test.
The driver's commments on the clutches on the CAT made me laugh. He clearly has no idea what he is talking about.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
4x4ord
Alberta
According to my math the Powerstroke's average crankshaft power output over the entire run would have been very close to 425 hp (assuming a 15% powertrain loss). Based on a torque curve with max torque of 1050 lb ft @1600 rpm and a peak horsepower of 475 @ 2800 rpm I expect the Powerstroke to make 425 HP at about 2400 rpm. So .... based on the math, it looks as though the Powerstroke wasn't holding anything back .... it put full fuel delivery out for the entire run up the hill.
Edit: I'm not sure where my mistake was but, 375 flywheel HP is more like what the Ford would have been generating .... not 425. The Duramax averaged more like 329 flywheel HP. (This assumes 15% driveline loss for both trucks and 75 hp to overcome air and rolling resistance for the Ford vs 67 HP for the GM.)
edited 01/25/20 01:55pm by 4x4ord *
4x4ord
Alberta
ksss wrote: This test seemed a lot more haphazard than what they have done in the past, particularily on the down hill portion. There is no question the Ford dominated the run up the hill. Looks like in this case the Ford actually performed like you would expect given its power advantage. GM clearly is going to have to find some more power to compete with the Ford 6.7 on this test.
Ford did dominate the uphill run. The difference in time indicates a 46 horsepower advantage that the Ford has which is a little more than the difference in advertised power ratings.
edited 01/25/20 01:56pm by 4x4ord *
