Boomerweps
Hills of PA
Wow! I thought a 2x2" hitch was pretty stout in my younger days and then they had the 2.5x2.5" on the 3/4 & 1 ton pickups. I see on the F250 Tremor test videos, it comes with a 3x3" hitch! I guess they are going to need a LOT of adapters to tow smaller trailers.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
gbopp
The Keystone State
Amazon is ready with the 3" Hitch Adapters.
blt2ski
Kirkland, Wa
Not surprised at this frankly. When I bought my dump truck moons ago, bed hitch maker mentioned, the 1/2" pin used in most 2" hitch applications was only strong enough for a 10-12k trailer. You needed a 5/8" to get to 15-20k, and 3-4' or larger for over this amount. Hence why most tow rigs towing REALLY heavy ball or pintle hitch trailers have the hitch bolted to s frame.
One would need to up the bar size to fit s bolt that was strong enough to handle s given size trailer one might pull in this manner.
Marty
Check RV.Net Blogs at: blog.rv.net
near Bishop, California
Don’t adapters lower max trailer weight?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
rjstractor
Maple Valley, WA
Also impressive is the 21,200 lb towing/2120 lb tongue weight rating on the hitch, the full capacity of the truck, without requiring WD. A far cry from the stock hitches of 15-20 years ago that only had a 5,000 lb weight carrying rating.
agesilaus
North Florida
Boomerweps wrote: Wow! I thought a 2x2" hitch was pretty stout in my younger days and then they had the 2.5x2.5" on the 3/4 & 1 ton pickups. I see on the F250 Tremor test videos, it comes with a 3x3" hitch! I guess they are going to need a LOT of adapters to tow smaller trailers.
My 2012 F350 has a 3 inch hitch with a 2.5 inch insert. So nothing new there. It is mainly a PITB to get the insert lined up so you can slide the locking pin thru it.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
dodge guy
Bartlett IL
Great. A bigger adapter to dodge on the road when they forget to remove them.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Travlingman
Jonesborough, TN
agesilaus wrote: Boomerweps wrote: Wow! I thought a 2x2" hitch was pretty stout in my younger days and then they had the 2.5x2.5" on the 3/4 & 1 ton pickups. I see on the F250 Tremor test videos, it comes with a 3x3" hitch! I guess they are going to need a LOT of adapters to tow smaller trailers.
If your hitch is stock, it is 2.5" hitch with a 2" adapter. Ford started using a 3" hitch on the 2017 models. Mine came with a 2.5" adapter and then a 2" sleeve. Here is a 2012 brochure where it shows the specs on 2nd page.
2017 F-350 King Ranch DRW
2014 Landmark Savannah
agesilaus
North Florida
After I posted that I started thinking that maybe it was a 2.5 with a 2 inch sleeve. So I think you are right. But I've never seen a 2.5 inch hitch to go in that receiver. But I never really looked there are plenty on Amazon.
Vanished
Central PA
Try using my truck to haul a bike rack on my dually - a 3" to 2.5" to 2" to 1.25" adapter... looks comical to be honest!
2019 Ford F350 4x4 diesel DRW
2021 Grand Design Momentum 28G
