RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel hitches
 > 5th wheel hitches
Page of 7
jerem0621
Tennessee
Posted: 01/29/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
"B&W makes a great hitch. They all make a DOT approved hitches."
I have a Friend that says to me "prove it" when I claim something. I have searched this statement every way possible with ZERO hits.
So I am respectfully asking you to prove your statement.
Good call Cummins12V98.
Since you didn't specify, I will address both parts of my statement that you quoted.
Respectfully, I can't substantiate the statement that B&W makes a great hitch. I don't use them as they are pretty expensive and my regular not B&W hitches work just fine and I see no need to upgrade my equipment at this time.
I was mostly going off your copious testimonies about how wonderful they are, and I believe YOU and many other B&W users that I know both online and off.
As to the DOT reference, you are correct. I can't find one either. Think before you post kinda thing I suppose. Sorry about that, my bad.
I can't even find a standard for build quality on ANY hitch in the US that a regular consumer would use. Admittedly, I didn't delve into the world of commercial trucks.
No argument from me I was wrong.
Thanks!
Jeremiah
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
Cummins12V98
on the road
Posted: 01/29/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the reply! I was referring to the DOT part. I should have specified.
I believe I have read somewhere CURT has some sort of standard, SAE possibly?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Wood chip
Nor Cal
Posted: 01/29/20 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have to remove your hitch often, the Trailer Saver BD-5 is the Rolls Royce of all hitches . This is just my humble opinion.
2017 Chevy HD 3500 Dually LTZ D/A combo crew cab / Bilstein 4600's / Ride Rite air bags w remote / 50 gal transfer flow Aux tank / Trailersaver BD5
2020 Arctic Fox 32-5m with most options + 17.5 wheel & tire combo
jerem0621
Tennessee
Posted: 01/29/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
This is interesting. I just couldn’t let it go. It seems there is an actual voluntary SAE standard for hitching called J2638.
Here is a neat webpage from Pullrite talking about the standard.
https://www.pullrite.com/J2638
I’m going to start researching this some more. Pretty interesting. They have to subject the hitch to 300,000 cycles at weights in excess of what the hitch will be rated in three different directions for a total of 900,000 cycles. Whew...
Thanks!
Jeremiah
Travlingman
Jonesborough, TN
Posted: 01/29/20 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Curt tests to SAE J2638.
2017 F-350 King Ranch DRW
2014 Landmark Savannah
JTrac
Oklahoma
Posted: 01/29/20 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
I checked on the Reese Goose Box. It says made to CSA (Canadian Standards Association) and SAE J2638 standards. Good to know. Thanks for pointing this out.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR, 4562 payload capacity
austinjenna
Columbus, Ohio
Posted: 01/30/20 04:08am Link  |  Quote  |  Print  |  Notify Moderator
I love my BD3 and would never go back to a standard hitch again.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
Cummins12V98
on the road
Posted: 01/30/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, knew I read something about that.
I wonder of the testing is in China. [emoticon]
2012Coleman
Posted: 01/30/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Someone suggested getting the hitch that's available locally - Etrailer.com will drop ship your B&W companion directly to your house - for free.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
ependydad
Here and there
Posted: 01/30/20 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've had both the B&W Companion (2 of them actually, upgraded from an older one to a newer one).
I only got rid of the B&W because my toy hauler was heavier than mine was rated for (20k for the post-mount version that mates up to their Turnoverball Gooseneck hitch).
I have nothing bad to say about my B&W. I had it from 2012-2018 and put many thousands of miles on it.
After getting rid of it, it took me 2 tries to end up with the Trailersaver TS3.
The good:
- the ride with the Trailersaver is awesome.
- the customer service is amazing.
The bad:
- the cost was pert near $3,000 for a new hitch.
- it's stupidly heavy at 300 lbs. but TS said it was fine for me to hang it from the kingpin.
The comparison - if our last move is pulling forward, it's not uncommon for the pin to be bound up against the head. We've had a tad bit of difficulty unhitching a couple of times now. I never experienced this with the B&W regardless of what my last move was - forward, backwards, using a crane and going sideways (ok, I didn't do that last one).
The ride is a bit better with the TS3 than the B&W but surprisingly not incredibly so.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Page of 7
 > 5th wheel hitches
