RV.Net Open Roads Forum: Truck Campers: Mattress Size & Thickness Recommendations (Bigfoot 2500)
 > Mattress Size & Thickness Recommendations (Bigfoot 2500)
adamis
Northern California
Posted: 01/28/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
The Mrs and I are looking at changing out our current mattress that came stock with the camper. We are planning on doing a memory foam mattress but I don't have the camper available to measure the size and thickness. If you have gone down this path before and happen to know off hand, I would appreciate it if you could post it here.
Second part... How did you get the old mattress out the door?
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
Kayteg1
California > Nevada
Posted: 01/28/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
They are queen size or 60 x 72 in both on my campers, but I would advise to measure it as who knows what manufacturer did on the camper.
I had 1 memory foam topper simply deteriorate in about 3 years, so better buy with long warranty.
To get mattress out the cabover, I used 2 ratchet straps to bend it about 150 degrees in the center and that pulled it out the passage.
Once you have it standing on its side on the floor, you can slide it via door.
GeoBoy
Bennington
Posted: 01/28/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I went to a foam distributor who also makes mattress and spec the size, thickness and firmness of the foam. Remember to factor in the thickness of the mattress cover to come up with total overall mattress thickness. I was surprised at the price, much lower than I expected.
WNYBob
Tonawanda, NY
Posted: 01/28/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
I traded mine out for a Sleep Number bed just like the one in our house.
TxGearhead
Posted: 01/28/20 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking mine is a queen short.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
guidry
Texas Cajun
Posted: 01/29/20 05:04am Link  |  Quote  |  Print  |  Notify Moderator
We just bought a memory foam topper on top of the stick mattress and it was great. Much cheaper and less hassle. Iā€™d suggest you try that first. Look at about a 3 or 4ā€ good memory foam topper.
Clarryhill
Midcoast Maine
Posted: 01/29/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Ours is regular queen-size (60 x 80). As far as getting old out and new in. See if you can get the new "installed". [emoticon][emoticon]
2014 Ford F450 PSD
2017 Lance 1172
adamis
Northern California
Posted: 01/29/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
I was able to measure it last night. It comes to 76"x60" and 7" thick. I will be talking to the mattress store to see what they offer.
bigfootford
Fair Oaks, California
Posted: 01/29/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
BF 2500 96 bed area is built for a SHORT QUEEN.
We went with a Bed in a Box to match our home bed which is exactly the same except the home bed is a Cal King.
The old mattress was easy to get out.
The Bed in a box was a monster..hahahaaa. It is a heavy turd.. SHAPE!.
It is a bit tall, we lost 2" of head room but boy is it comfy. Have about 20,000 miles on the camper with it in there. Several Weeks of nights..
I tried to search Bed in a Box for their Short Queen "Original" and I see that they do not specify the short Queen. As a note the mattress is 11 inches.
Jim
* This post was edited 01/29/20 10:49am by bigfootford *
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
welsteach
AK
Posted: 02/27/20 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just went through all of this. Bigfoot is definitely a queen short. Our original was 6ā€ deep. We have cabinets to open at the foot of the bed, so we went 6ā€ again of bed in a box memory foam. Still have room for thicker bedding (in Alaska, so that is a must). Enjoy!
