RV.Net Open Roads Forum: Travel Trailers: Looking at new better tires, need advice.
 > Looking at new better tires, need advice.
Huntindog
Phoenix AZ
Posted: 01/29/20 03:01am Link  |  Quote  |  Print  |  Notify Moderator
BarryG20 wrote:
I also would look at the gy endurance
You might think about the 215 size instead of the 205 size as it gives you a bit more weight capacity and isn’t any larger diameter so should fit fine. Though not knowing the weight of your trailer you may not need any additional weight capacity cushion
All other specs being the same, a 215 WILL be taller than a 205.
Not saying it won't fit, or that it's a bad idea.... Just that it WILL be taller
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
Gulfcoast
Alabama
Posted: 01/29/20 03:48am Link  |  Quote  |  Print  |  Notify Moderator
A good deal...
$99
* This post was edited 01/29/20 03:56am by Gulfcoast *
guidry
Texas Cajun
Posted: 01/29/20 04:59am Link  |  Quote  |  Print  |  Notify Moderator
MarkTwain wrote:
1. look at the side of the tire and look for numbers like "122/05" that is the week and year the tire was manufactured. Many RVers keep tires for about 5 years and then replace them.
2. Look at the possibility of switching to 15" rims for more tire capacity and stability.
3. I prefer to have the highest rated tire that will fit on my trailer i.e. G rated tires on my 15th. wheel..
This! Go to the highest load rating you can; I’ve gone through several brands of tires and it wasn’t until I went up two load ranges (now with G rates on my 5th wheel too) that I’m comfortable with my tires! This is the best advice you’ll get.
Camreal
Kerrville, Tx
Posted: 01/29/20 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Ive been pleased with Maxxi tires and not pleased with Carlile blowouts.
dodge guy
Bartlett IL
Posted: 01/29/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
A 215 70 14 will be the same height as a 205 75 14, jus a bit wider.
With hat said I would only consider the Carlisle HD tires.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Mike134
Elgin
Posted: 01/29/20 05:57am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking also to change to a 215 overall diameter is 1/4" bigger with 14" rims
mgirardo
Brunswick, GA
Posted: 01/29/20 05:59am Link  |  Quote  |  Print  |  Notify Moderator
I think there is something wrong with your calculator. A 215 75 r14 tire has a Diameter of 26.7 inches while a 205 75 r14 tire has a Diameter of 26.1 inches. Not a significant difference, but the 215 is a taller tire.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
GrandpaKip
Flat Rock
Posted: 01/29/20 06:11am Link  |  Quote  |  Print  |  Notify Moderator
If you go with the GY Endurance, make sure your rims are rated for 65 psi. The 14” D tires have plenty of load capacity for a trailer of 7000 pounds gross.
The 205 will carry a bit over 2000 pounds each and the 215 about 200 pounds more each. Either will be adequate.
I have the 215/75/14’s on mine and have been very satisfied.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
jesseannie
Roseburg, OR
Posted: 01/29/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I put bias ply Carlisle on my trailer it is about the same weight as yours. I get them rotated each year and have had no problems.
Jesseannie
BarryG20
Castle Rock, Colorado
Posted: 01/29/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I got my info from tire Rack as they have a nice screen that shows all the specs of the tire sizes in one screen it shows them to be the same diameter if that is wrong my apologies.
https://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Endurance
However, now after a quick check on Goodyears site Tire Rack does appear to be wrong. Goodyears site shows that there is in fact a difference as was stated after my post of 26.1 vs 26.7 diameter so my apologies for providing incorrect info. As for my trust in Tire Rack it has now wavered and in the future will verify with the manufacturers website in regards to tire info I glean from Tire Rack.
That being said I personally would still consider going up to that size depending on what my trailer weight was to gain a bit more tire capacity cushion if I thought it was needed but unknown without a trailer weight. That is if the 6/10's of an inch in diameter increase is still doable on the trailer
PS Don't remember who brought it up but whomever good catch on my mistake
2016 Jayco 28.5 RLTS
