RV.Net Open Roads Forum: Beginning RVing: Electric blanket and inverter
 > Electric blanket and inverter
Sunset Gypsies
AL
Posted: 02/02/20 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Found an electric blanket that the inverter does not fry.
SoftHeat by Perfect Fit | Luxury Low-Voltage Electric Heated Blanket
The control and blanket run on 18 volt DC, separate power supply feeds the control from 120 vac. Works fine with voltage from a modified sine wave inverter.
Could probably replace the power supply with a 12 to 18 volt DC to DC converter to save energy.
* This post was edited 02/02/20 06:52pm by an administrator/moderator *
Morro Bay, CA
Posted: 02/02/20 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Everything is more safe with a pure sine wave inverter.
valhalla360
No paticular place.
Posted: 02/02/20 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Unless I'm misreading, it doesn't need a DC power source. It's 120v AC powered but the heating circuits are DC. Conversion is all internal to the control unit.
Changing the voltage won't change the efficiency. Wattage is what determines heat output. Wattage is Volts x Amps If you crack open the controller and mess with the voltage assuming you don't increase the amps, you do reduce power consumption but you could achieve the same effect by simply turning down the thermostat so it runs for a shorter period of time.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Wherever I happen to park
Posted: 02/03/20 04:58am Link  |  Quote  |  Print  |  Notify Moderator
The Controller it appears runs off a DC supply that is MSW friendly
That's the problem when I was a child everythign was thermal breakers basically, MSW, PSW, DC it mattered not.. But today the controls are electronic and MSW tends to fry so this thread is a FIND.
Home is where I park it.
Sunset Gypsies
AL
Posted: 02/03/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Yes it does work fine as it is. I was referring to power loss in the main inverter (12vdc to 120ac) and the blanket's power supply (120vac to 18vdc). A 12vdc to 18vdc converter replacing the blanket's power supply and running of the 12 volt circuits might be more efficient as it would remove the power loss in the inverter, but probably not enough to justify the cost of the converter.
theoldwizard1
SE MI
Posted: 02/03/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
At my parents house, the master bedroom was an addition with very poor heat. Not uncommon to drop into the 50s in there during winter.
They said a heated mattress pad and a couple of heavy blankets were more comfortable than an electric blanket.
SidecarFlip
SE Michigan
Posted: 02/03/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
+1. Besides a quality PSW isn't all that more expensive.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
wopachop
lb
Posted: 02/03/20 11:58am Link  |  Quote  |  Print  |  Notify Moderator
My friend is always cold and looked into electric blankets. They can form some type of field that the human body does not like. I dont remember the details besides deciding it's not good to sleep under them.(some of them.....all of them???)
Instead she cranks it full blast for an hour and turns it off before climbing into bed.
Just something to research if you care about that stuff.
Sunset Gypsies
AL
Posted: 02/03/20 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes you are right. Most electric blankets use AC to heat the blanket which emits EMF. The blanket I referred to uses DC to heat it which reduces the EMF considerably.
valhalla360
No paticular place.
Posted: 02/03/20 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
That makes more sense but as you say, how much power will you really save? Also, I'm betting the control head is not designed to be pulled apart and rewired, so how sturdy will it be an how much cost and effort will be involved.
